Enigma2 Linux Receiver
Jan  1 03:00:17 OCTAGON-SF-4008 daemon.info avahi-daemon[1319]: New relevant interface wlan0.IPv4 for mDNS.
Jan  1 03:00:17 OCTAGON-SF-4008 daemon.info avahi-daemon[1319]: Network interface enumeration completed.
Jan  1 03:00:17 OCTAGON-SF-4008 daemon.info avahi-daemon[1319]: Registering new address record for fe80::1e87:2c
ff:fec7:2c38 on wlan0.*.
Jan  1 03:00:17 OCTAGON-SF-4008 daemon.info avahi-daemon[1319]: Registering new address record for 192.168.1.9 o
n wlan0.IPv4.
Jan  1 03:00:18 OCTAGON-SF-4008 daemon.info avahi-daemon[1319]: Server startup complete. Host name is OCTAGON-SF
-4008.local. Local service cookie is 2601336616.
Jan  1 03:00:19 OCTAGON-SF-4008 daemon.info avahi-daemon[1319]: Service "OCTAGON-SF-4008" (/services/ssh.service
) successfully established.
Jan  1 03:00:19 OCTAGON-SF-4008 daemon.info avahi-daemon[1319]: Service "OCTAGON-SF-4008" (/services/sftp-ssh.se
rvice) successfully established.
Jan  1 03:00:19 OCTAGON-SF-4008 daemon.info avahi-daemon[1319]: Service "FTP file server on OCTAGON-SF-4008" (/s
ervices/ftp.service) successfully established.
Jan  1 03:00:25 OCTAGON-SF-4008 daemon.crit automount[1203]: key "VideoASUSK53S" not found in map source(s).
Jan  1 03:00:25 OCTAGON-SF-4008 daemon.crit automount[1203]: key "MEDIA" not found in map source(s).
Jan 10 14:05:02 OCTAGON-SF-4008 daemon.notice ntpdate[1182]: step time server 194.27.222.5 offset 1547118273.359
789 sec
Jan 10 14:05:33 OCTAGON-SF-4008 cron.err crond[1255]: time disparity of 25785305 minutes detected
Jan 10 14:06:50 OCTAGON-SF-4008 authpriv.info login[2718]: pam_unix(login:session): session opened for user root
by (uid=0)
Jan 10 14:06:50 OCTAGON-SF-4008 authpriv.notice login[2735]: ROOT LOGIN  on '/dev/pts/0' from '::1'
root@OCTAGON-SF-4008:~#
Aydın Hocam nekadar uzun sürdü bu mesajlar ama sanıyorum bitti.:oops:
Sistemde takılı bulunan 4 GByte lık SDCARD ile ilgili hatalar görüyorum Özgür. Ama harddisk ile ilgili ve ARM'in boot ettiği SPI flash ile ilgili bir hata yok. Sistem açılışı normal. O harici SDCARD'ı da herhalde sen taktın. Onu çıkarıp tekrar çalıştırmayı dene bakalım.
Bir de bu hatalar ciddi. Acaba harddisk'i formatlarken kurulum prosedürünü tam olarak doğru yaptın mı?
Aydın Hocam 4gb ram USB bellekten kullanmştım doğrudur ama sonra HDD ye döndüm. HDD yide Linux sistemde hiç formatlamadım malesef doğrudur. HDD yi windows ortamında hızlı format yapıp taktım. Müzik kayıtları var. Şimdide Kodide hata vermiyor ama siyah ekran bunun sebebide sanıyorum çok güncelleme gelmiş ve ben hiç birini yapmadım. Çünkü geçen yıl denemiştim güncelleme sonrası Start Linux yazıyor öğle kalıyor cihaz. USB ile Baştan imaj yükleyip o şekilde açılıyor oda çok uzun sürüyor. Ayrıca Hocam bu cihazda ayarlar dipsiz kuyu gibi şimdi örnek veriyorum ekrandaki kanal geçişlerinden sonra durum bilgisi frekans barını solarak geçişe ayarlıyorsunuz diyelim 15 saniyede yavaş yavaş silinerek kaybolsun. OK .Sonra acaba bu ayarı nereden yapmıştık. Hah işte sık kullanım ve tekrarda hızlı bir şekilde yapabiliyorsunuz. Ama çok zevkli enigma linux tabanlı cihazı kullanmak . Aydın hocam siz olsanız bu cihaza her şeyi yaptırırsınız eminim. :) Bakın ben root şifreyi bile nasıl değiştireceğimi bilmiyorum. :( Belki bilenler lambur lumbur bu cihaza bağlanıyorlardır. Server bilgilerini alıp kullanabilirler.:mad: Benim bu cihazda en çok kullandığım /etc/tuxbox/config/oscam yolunda Oscam dosyasını editleyip satın aldığım server bilgilerini girip düzenlemek. Ama şöyle bir durumda var bana CCCam dosyası olarak veriyorlar bende onu programla oscam a çevirip dosyayı oluşturuyorum. Şu Aşağıdaki şekilde yapıyorum. Ama bu bir bölümü tabi Yüzlerce satır hatta çok fazlası olabilir. Burada yapılanlar daha % 3 gibi diyelim.. Benim bilgim çok çok az Hocam.
[reader]
label = SoftCam.Key
protocol = constcw
device = /etc/tuxbox/config/SoftCam.Key
caid = 0D00,0D02,090F,0500,1801,0604,2600,FFFF,0E00,4AE1,1010
ident = 0D00:000000,000004,000010,000014,000020,0000C0,0000C4,0000C8,0000CC;0D02:000000,00008C,0000A0,0000A4,0000A8;090F:000000;0500:000000,030B00,023800,021110,007400,007800;1801:000000,007301,001101,002111;0604:000000;2600:000000;FFFF:000000;0E00:000000;4AE1:000000,000011,000014,0000FE;1010:000000
group = 1
[reader]
label = constant.cw
protocol = constcw
device = /usr/keys/constant.cw
group = 1
[reader]
label = oscam.constant.cw
protocol = constcw
device = /etc/tuxbox/config/oscam.constant.cw
group = 1
[reader]
label = constkeys
protocol = constcw
key = 0102030405060708091011121314
reconnecttimeout = 0
caid = 06AD
group = 1
[reader]
label = constkeys
protocol = constcw
caid = 0B00
group = 1
[reader]
label = Newcamd
description = Newcamd Example
protocol = newcamd
device = server
user = username
password = password
group = 1
[reader]
label = csat
protocol = cccam
device =
inactivitytimeout = 30
fallback = 1
group = 1
blockemm-unknown = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 1
lb_force_fallback = 1
disablecrccws = 1
cccversion = 2.3.0
audisabled = 1
[reader]
label = 798k7noq.xdream.org
protocol = cccam
device = 798k7noq.xdream.org,1003
user = vrxkyxrr
password = kethu7k7
group = 1
cccversion = 2.1.3
ccckeepalive = 1
Bilinen harcı alem uydu alıcılarına göre (mesela Next vs) bu nasıl bir avantaj sağlıyor Özgür? Tek farkı üzerinde açık kaynak linux olması ve kullanıcının da işletim sistemine erişiyor olması mı?
Aydın Hocam Bu cihaz 4K ve tabiki Ver 2. HDMI kablo ile dehşet görüntü var., Nextler sadece HD, Nextlerde 4K olanda var android ama çok ağır. Ben bir süre kullandım Annemlere verdim. Buyrun Next 10000 Android resimler. Made in China
Octagon Sf 4008 kanal geçişleri süper hızlı açık kod Enigma2 Linux yazılım, yani geliştirilebilir ve tabiki 4K yayınları izlenebilir ve Multimedia. Almanya üretimi.
Güzel cihaz. Binlerce kanal alıyordur, ama Digitürk'teki belgesel ve eurosport'a çok alıştım, sf4008 alınca herhalde bunları artık seyredemeyiz.
Aydın Hocam şunuda belirtmek istiyorum. Çoğu kişi HDMI kablo dendiği zaman gider alır TV ye takıp bağlantıyı yapar. Olmadı işte durum öyle değil bakın HDMI kablonun donanım versiyonları var kullandığınız cihaza göre durum değişebilir. Siz eski bir LCD veya hd led tv kullanıyorsanız sorun olmaz. Ama 4K TV ve receiver kullanıyorsanız o zaman çok şey farkeder.
Bakın Aşağıdaki tabloda HDMI kablo Ver farkları. (Bu tabloda eskidi sayılır):)Piyasada çok fazla miktarda ver 1.4 Mevcut ve siz aştırmassanız , bilmiyorsanız sizede 1.4 satıverirler. Ha şunuda duydum 1.4 olan kabloyu 2.0 olarak satışa sunabilirler.
HDMI ver 2.0 altındaki kablolarda yenileme hızı 30Hz kalıyor. 60Hz desteklemiyor.
Yasal, Legal abonelikle izlenebiliyor Aydın Hocam. Sanıyorum PCMCIA Modül ve Modül Destekli uydu akıcıları ile Tüm belgesel ve spor kanallarını platform üyeliğinde verilen Modül veya smartcard ile sorunsuz izleyebilirsiniz.
Yani müşterisi olduğum digitürk'ün smartcard'ını buna takıp digitürk yayınlarının tamamını izleyebiliyor muyuz? Eğer öyle ise ben hemen yarın alırım bundan bir tane :)
Veya senin dreambox gelince bana uygun fiyata bu elindeki SF4008'i verirsin ;)
Tamam şifre nasıl değiştirilir cevap verdiler bir ara bende şifreyi değiştireyim.
kullanıcı adı root kesinlikle değiştiremezsiniz(root linuxta yetki verilmiş demektir) ama şifrenizi değiştirebilirsiniz puty veya telnet passwd yazın sizden yeni şifre ister unutmayacağınız bir şifre yazın yazarken görünmez telaşlanmayın hemen arkasından tekrar şifrenizi yazmanızı ister yazın enter deyince succeful yazarsa değişmiş demektir kolay gelsin
yaptığınız değişiklikten sonra
login:root
şifre: (puty veya telnetten verdiğiniz dir kesinlikle unutmayınız çünkü bağlanamazsınız)
Eğer seri terminal varsa şifreyi bilmezsen bile gene bağlanabilirsin ;)
s4met
Dr. Bülent Başaran,
Yonga Tasarım Özdevinimcisi
Üç güzel "çocuk" babası
