Mikro Step
- 25 Eylül 2022
- 3,749
Elimdeki scope 100Mhz. Kataloguna gozatarken girisler icin overvoltage protection kisminda asagidaki degerle karsilastim.
Overvoltage protection ±100 V (DC + AC peak) up to 10 kHz
Giris voltajinin +/- 100v a dayanabildigi yazmis. Ancak frekans icin 10Khz limit konmus.
100Mhz scopa uygulanan sinyal 100v olabilir ama frekansi max 10Khz olacak olayi kafami karistirdi.
Bir aramada da scoplar hakkinda genel bir aciklama yapan asagidaki metinle karsilastim. Bu aciklamada da 10Khz limitten bahsediliyor.
Protecting 1 MΩ inputs
A 1 MΩ input has a typical maximum voltage rating of 400 volts (DC + peak AC) for input frequencies less than or equal to 10 kilohertz (kHz). While a considerably more rugged specification, it may still be damaged by high-amplitude voltage transients caused by lightning or other electromagnetic interference (EMI) phenomena.
A 1 MΩ input can be protected using surge protectors such as spark gaps, gas discharge tubes, or diodes that break down to discharge electrical surges to ground before they can cause damage.
