No default constructor exists for class hatası
Bowman
7 Ekim 2022
Github'da bir medyan filtresi kütüphanesi var. Ben bunu alıp kendi uygulamamda kullanmak istedim. Kütüphane bu. Keil'e çektim kodu aynı şekilde. Ama konu başlığından da anlayacağınız üzere "no default constructor exists for class hatası" alıyorum. C++'a aşina olmadığım için hatanın sebebini anlayamadım.
Header dosyası:
C++:
#ifndef __MEDIANFILTER_H_
#define __MEDIANFILTER_H_
#include "M031Series.h"
#include <stdlib.h>
#include <stdbool.h>
#define constrain(amt,low,high) ((amt)<(low)?(low):((amt)>(high)?(high):(amt)))
class MedianFilter {
    public:
        MedianFilter(int size, int seed);
      ~MedianFilter();
        int in(const int & value);
      int out();
    private:
      uint8_t medFilterWin;      // number of samples in sliding median filter window - usually odd #
      uint8_t medDataPointer;       // mid point of window
      int     * data;                        // array pointer for data sorted by age in ring buffer
        uint8_t * sizeMap;               // array pointer for locations data in sorted by size
      uint8_t * locationMap;         // array pointer for data locations in history map
        uint8_t oldestDataPoint;     // oldest data point location in ring buffer
        int32_t totalSum;
extern MedianFilter myMedian;
#endif
Source dosyası:
C++:
#include "medianFilter.h"
MedianFilter::MedianFilter(int size, int seed)
    medFilterWin = constrain(size,3,255);
    medDataPointer  = size >> 1;
    data = (int*)calloc (size, sizeof(int));
    sizeMap = (uint8_t*)calloc(size, sizeof(uint8_t));
    locationMap = (uint8_t*)calloc(size, sizeof(uint8_t));
    oldestDataPoint = medDataPointer;
    totalSum = size * seed;
     for(uint8_t i = 0; i < medFilterWin; i++) // initialize the arrays
      sizeMap[i]     = i;      // start map with straight run
      locationMap[i] = i;      // start map with straight run
      data[i]        = seed;   // populate with seed value
MedianFilter::~MedianFilter()
  // Free up the used memory when the object is destroyed
  free(data);
  free(sizeMap);
  free(locationMap);
int MedianFilter::in(const int & value)
   // sort sizeMap
   // small vaues on the left (-)
   // larger values on the right (+)
   bool dataMoved = false;
   const uint8_t rightEdge = medFilterWin - 1;  // adjusted for zero indexed array
   totalSum += value - data[oldestDataPoint];  // add new value and remove oldest value
   data[oldestDataPoint] = value;  // store new data in location of oldest data in ring buffer
   // SORT LEFT (-) <======(n) (+)
   if(locationMap[oldestDataPoint] > 0) // don't check left neighbours if at the extreme left
      for(uint8_t i = locationMap[oldestDataPoint]; i > 0; i--)   //index through left adjacent data
         uint8_t n = i - 1;   // neighbour location
         if(data[oldestDataPoint] < data[sizeMap[n]]) // find insertion point, move old data into position
            sizeMap[i] = sizeMap[n];   // move existing data right so the new data can go left
            locationMap[sizeMap[n]]++;
            sizeMap[n] = oldestDataPoint; // assign new data to neighbor position
            locationMap[oldestDataPoint]--;
            dataMoved = true;
         else
            break; // stop checking once a smaller value is found on the left
   // SORT RIGHT (-) (n)======> (+)
   if(!dataMoved && locationMap[oldestDataPoint] < rightEdge) // don't check right if at right border, or the data has already moved
      for(int i = locationMap[oldestDataPoint]; i < rightEdge; i++)   //index through left adjacent data
         int n = i + 1;   // neighbour location
         if(data[oldestDataPoint] > data[sizeMap[n]]) // find insertion point, move old data into position
            sizeMap[i] = sizeMap[n];   // move existing data left so the new data can go right
            locationMap[sizeMap[n]]--;
            locationMap[oldestDataPoint]++;
         else
            break; // stop checking once a smaller value is found on the right
   oldestDataPoint++;       // increment and wrap
   if(oldestDataPoint == medFilterWin) oldestDataPoint = 0;
   return data[sizeMap[medDataPointer]];
int MedianFilter::out() // return the value of the median data sample
main kodda myMedian. ile ulaşabiliyorum nesnenin fonksiyonlarına. Fakat source dosyasında bu hatayı alıyorum. Eğer source dosyasındaki medianFilter myMedian'ı yorum yaparsam da bu sefer main kodda myMedian undefined olarak gözüküyor. Nasıl çözebilirim?
Hata zaten herşeyi söylüyor, class için "default constructor" yok. Default contructor, herhangi bir argüman almayan constructor.
İki şekilde çözebilirsin:
1) Default constructor tanımla
C++:
    public:
        MedianFilter();
      ~MedianFilter();
MedianFilter::MedianFilter()
    /* artik ne yapilmasi gerekiyor sen bileceksin */
2) Class değişkenini tanımlarken mevcut constructor argümanlarını belirt
MedianFilter myMedian(5, 7); /* burada 5 ve 7 yerine olmasi gereken degerleri kullan */
yaxe22
