8, 10, 12 bit SPI DAC
Dede
24 Mayıs 2024
Geçici ve kalıcı hafıza çeşitleri olan DAC ürünleri...
8/10/12-Bit Digital-to-Analog Converters, 1 LSb INL
Single/Dual Voltage Outputs with SPI Interface
Features
• Memory Options:
- Volatile memory: MCP48CVBXX
- Nonvolatile memory: MCP48CMBXX
• Operating Voltage Range:
- 2.7V to 5.5V – Full specifications
- 1.8V to 2.7V – Reduced device specifications
• Output Voltage Resolutions:
- 8-Bit: MCP48CXB0X (256 steps)
- 10-Bit: MCP48CXB1X (1024 steps)
- 12-Bit: MCP48CXB2X (4096 steps)
• Nonvolatile Memory (MTP) Size: 32 Locations
• 1 LSb Integral Nonlinearity (INL) Specification
• DAC Voltage Reference Source Options:
- Device V DD
- External V REF pin (buffered or unbuffered)
- Internal band gap (1.214V typical)
• Output Gain Options:
- 1x (Unity)
- 2x (available when not using internal V DD as
voltage source)
• Power-on/Brown-out Reset (POR/BOR)
Protection
• Power-down Modes:
- Disconnects output buffer (High-Impedance)
- Selection of V OUT pull-down resistors
(100 k or 1 k)
• SPI Interface:
- Supports ‘00’ and ‘11’ modes
- 50 MHz write speed
- 25 MHz read speed
• Package Types:
- Dual: 16-lead 3 x 3 QFN, 10-lead MSOP,
10-lead 3 x 3 DFN
- Single: 16-lead 3 x 3 QFN, 10-lead MSOP,
10-lead 3 x 3 DFN
• Extended Temperature Range: -40°C to +125°C
Datasheet MCP48CXBXX
DataSheet MCP48CXDX1/2
CXB ve CXD serisi arasındaki fark nedir? Datasheet'lere bakınca tamamen aynı gibi duruyorlar :bilmem3:
Sanırım üreticiye sormak lazım bunu.
Farklı isimlendirildiyse illaki bi fark wardır ama bilmemkaç sayfa dökümanın tamamını karşılaştırmak ta zor iş.
LostFearLess
Freemont2.0 wrote on herbokolog's profile.
Freemont2.0 wrote on posta's profile.
