mesaj bitti
[code lang="cpp" title="the title" highlight="6"]
void setup()
Serial.begin(115200);
void loop()
uint16_t count = 0;
while (true)
++count;
char buffer[100];
snprintf(buffer, sizeof(buffer), "count = %u\n", count);
Serial.print(buffer);
[/code]
asdfasdf
C++:
#include "numicro_8051.h"
#include "debug_log.h"
#define RAVG_BUFCNT 20
typedef struct
    unsigned int buffer[RAVG_BUFCNT];
    unsigned char index;
    unsigned long sum;
} RAVG;
static float adc_vdd;
static RAVG ravg_voltage;
static RAVG ravg_current;
#define OFFSET_VOLTAGE 0.016
#define SCALE_VOLTAGE 39.96
#define OFFSET_CURRENT 0.100
#define SCALE_CURRENT 7.032
static const float real_table_v[] =
    0.3,
    0.4,
    0.5,
    1.0,
    2.0,
    3.0,
    5.0,
    10.0,
    20.0,
    40.0,
    80.0,
    100.0,
static const float adc_table_v[] =
    0.011,
    0.02,
    0.05,
    0.274,
    1.188,
    2.214,
    4.235,
    9.11,
    19.14,
    39.31,
    79.83,
    100.14,
static const float real_table_i[] =
    0.05,
    0.1,
    0.2,
    0.3,
    0.5,
    1.0,
    1.5,
    2.0,
    4.0,
    8.0,
    10.0,
static const float adc_table_i[] =
    0.057,
    0.106,
    0.207,
    0.311,
    0.527,
    1.054,
    1.55,
    2.046,
    4.01,
    8.03,
    10.1,
float interpolate(const float* real_table,
                  const float* adc_table,
                  unsigned int size,
                  float adc_value)
    unsigned int i;
    for (i = 0; i < (size - 1); i++)
        if ((adc_table[i] <= adc_value) &&
             adc_value < adc_table[i + 1])
            break;
    float adc_low = adc_table[i];
    float adc_high = adc_table[i + 1];
    float real_low = real_table[i];
    float real_high = real_table[i + 1];
    float real_value = real_low + ((adc_value - adc_low) / (adc_high - adc_low)) * (real_high - real_low);
    return real_value;
static void ravg_run(RAVG* ravg, unsigned int data)
    ravg->sum -= ravg->buffer[ravg->index];
    ravg->sum += data;
    ravg->buffer[ravg->index] = data;
    ravg->index = (ravg->index + 1) % RAVG_BUFCNT;
static float ravg_average(RAVG* ravg)
    return (float)ravg->sum / RAVG_BUFCNT;
static unsigned int adc_read_raw(void)
    clr_ADCCON0_ADCF;
    set_ADCCON0_ADCS;
    while ((ADCCON0 & SET_BIT7) == 0)
    unsigned int data = (ADCRH << 4) | (ADCRL & 0x0f);
    return data;
unsigned int adc_read_voltage_raw(void)
    ENABLE_ADC_AIN6;
    return adc_read_raw();
unsigned int adc_read_current_raw(void)
    ENABLE_ADC_AIN5;
static unsigned int adc_bandgap_stored(void)
    unsigned int data;
    set_IAPEN;
    IAPAL = 0x0C;
    IAPAH = 0x00;
    IAPCN = 0x04;
    set_IAPGO;
    data = IAPFD;
    IAPAL = 0x0d;
    IAPAH = 0x00;
    IAPCN = 0x04;
    set_IAPGO;
    data = (data << 4) | (IAPFD & 0x0f);
    clr_IAPEN;
    debug_log(1, "data = %u\n", data);
    return data;
static unsigned int adc_bandgap_actual(void)
    ENABLE_ADC_BANDGAP;
    adc_read_raw();
    adc_read_raw();
    adc_read_raw();
    unsigned int data = adc_read_raw();
    return data;
void adc_task(void)
    ravg_run(&ravg_voltage, adc_read_voltage_raw());
    ravg_run(&ravg_current, adc_read_current_raw());
/* #define _CALIBRATE_ */
float adc_read_voltage(void)
    float value = ravg_average(&ravg_voltage) * adc_vdd / 4095.0;
    value = (value - OFFSET_VOLTAGE) * SCALE_VOLTAGE;
#ifndef _CALIBRATE_
    value = interpolate(real_table_v,
                        adc_table_v,
                        sizeof(real_table_v) / sizeof(real_table_v[0]),
                        value);
#endif
    return value;
float adc_read_current(void)
    float value = ravg_average(&ravg_current) * adc_vdd / 4095.0;
    value = (value - OFFSET_CURRENT) * SCALE_CURRENT;
#ifndef _CALIBRATE_
    value = interpolate(real_table_i,
                        adc_table_i,
                        sizeof(real_table_i) / sizeof(real_table_i[0]),
                        value);
#endif
    return value;
void adc_init(void)
    unsigned int bg_stored = adc_bandgap_stored();
    unsigned int bg_actual = adc_bandgap_actual();
    float vbg = 3072.0 * bg_stored / 4096.0;
    adc_vdd = 4095.0 / bg_actual * vbg / 1000.0;
    debug_log(1, "bgs = %u, bga = %u, vbg = %f, vdd = %f\n",
              bg_stored, bg_actual, vbg, adc_vdd);
bueno
