Dede
- Katılım
- 24 Mayıs 2024
- Mesajlar
- 1,592
Biryerden elime 2TB WD mycloud tek diskli NAS aleti geçti.
Kaba bir kitaplık gibi bişey.
Uğraşmaya değermi bilemedim.
HDD ölmüş.
SSH Raporu şöyle:
İçinde tek WD RED / RED Plus 2TB (WD20EFZX / WD20EFRX / WD20EFAX) war.
Üstelikte firmware diskin içine gömülü.
WD sanırım artık destek te wermiyor.
Ne dersiniz yeni bir hard disk alıp denesemmi?
HDD ölmüş.
SSH Raporu şöyle:
=== START OF INFORMATION SECTION ===
Device Model: WDC WD20EFRX-68EUZN0
Serial Number: WD-WCC4M5FAES9H
Firmware Version: 82.00A82
User Capacity: 2,000,398,934,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 9
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Mon Dec 1 12:46:06 2025 PST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (26580) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 188 174 021 Pre-fail Always - 3566
4 Start_Stop_Count 0x0032 084 084 000 Old_age Always - 16350
5 Reallocated_Sector_Ct 0x0033 133 133 140 Pre-fail Always FAILING_NOW 1971
7 Seek_Error_Rate 0x002e 200 198 000 Old_age Always - 0
9 Power_On_Hours 0x0032 001 001 000 Old_age Always - 75754
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 62
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 52
193 Load_Cycle_Count 0x0032 194 194 000 Old_age Always - 19653
194 Temperature_Celsius 0x0022 106 092 000 Old_age Always - 41
196 Reallocated_Event_Count 0x0032 161 161 000 Old_age Always - 39
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
Warning: ATA error count 50756 inconsistent with error log pointer 3
ATA Error Count: 50756 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 50756 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 61 46 00 00 00 a0 Device Fault; Error: ABRT
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
ef 03 46 00 00 00 a0 08 6d+18:56:45.628 SET FEATURES [Set transfer mode]
ec 00 00 00 00 00 a0 08 6d+18:56:45.613 IDENTIFY DEVICE
c8 00 40 00 e9 e6 e0 08 6d+18:56:44.945 READ DMA
ec 00 00 00 00 00 a0 08 6d+18:56:44.919 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 08 6d+18:56:44.899 SET FEATURES [Set transfer mode]
Error 50755 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
04 61 40 00 e9 e6 e0 Device Fault; Error: ABRT 64 sectors at LBA = 0x00e6e900 = 15132928
ec 00 00 00 00 00 a0 08 6d+18:56:44.884 IDENTIFY DEVICE
c8 00 40 00 e9 e6 e0 08 6d+18:56:44.216 READ DMA
Error 50754 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
ec 00 00 00 00 00 a0 08 6d+18:56:44.189 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 08 6d+18:56:44.170 SET FEATURES [Set transfer mode]
Error 50753 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
ec 00 00 00 00 00 a0 08 6d+18:56:44.154 IDENTIFY DEVICE
c8 00 40 00 e9 e6 e0 08 6d+18:56:43.487 READ DMA
Error 50752 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
ec 00 00 00 00 00 a0 08 6d+18:56:43.460 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 08 6d+18:56:43.440 SET FEATURES [Set transfer mode]
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
root@WDMyCloud root #
