Dede
- 24 Mayıs 2024
- 1,588
Features:
General:
• Power Supply Voltage Range from 3V to 42V
• Sleep (Deep Sleep) Mode With Maximum 20 μA Current Consumption With Full Wake-Up Capability (Local Wake-Up)
• 3.3V or 5V Microcontroller Interface
• Up to 4 MHz SPI Bus for Device Configuration and Register Access
• SPI Frame Error Detection
• Dedicated NIRQ Pin for MCU External Interrupt in Order to Report Events Directly
• Input-Output Reset Pin (NRES) With Variable Reset Length to Support a Wide Variety of Microcontrollers
• Available in AEC-Q100 Grade 0, High Temperature Range (H): -40°C to 150°C
• Available in Non-Automotive Extended Temperature Range (E): -40°C to 125°C
• Packages: VQFN48, VQFN40 With Wettable Flanks and Exposed Pad, Both Have Moisture Sensitivity Level (MSL) 1
Applications:
• Automotive — Fuel, Water or Oil Pumps, Cooling Fans, Roots Blowers, Steering, Sunroof, Trunk Opening, Seat Adjustment
• Home Appliances Using BLDC Motor Control
• Power Tool Motors
• Hobby Aircraft, Boats, Drones or Vehicles
ATA6847L Datasheet
General:
Applications:
• Power Tool Motors
ATA6847L Datasheet
