fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin$ sudo tar -xjf Jetson_Linux_R35.4.1_aarch64.tbz2
[sudo] password for fidenet:
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin$ cd Linux_for_Tegra/
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra$ cd rootfs/
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra/rootfs$ sudo tar -xjf Jetson_Linux_R35.4.1_aarch64.tbz2^C
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra/rootfs$ cd ..
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra$ cd ..
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin$ cd Linux_for_Tegra/rootfs/
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra/rootfs$ sudo tar -xjf ../../Tegra_Linux_Sample-Root-Filesystem_R35.4.1_aarch64.tbz2
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra/rootfs$ sudo apt install net-tools
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
net-tools is already the newest version (1.60+git20181103.0eebece-1ubuntu5).
0 upgraded, 0 newly installed, 0 to remove and 128 not upgraded.
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra/rootfs$ sudo apt-get install openssh-server
The following additional packages will be installed:
ncurses-term openssh-sftp-server ssh-import-id
Suggested packages:
molly-guard monkeysphere ssh-askpass
The following NEW packages will be installed:
ncurses-term openssh-server openssh-sftp-server ssh-import-id
0 upgraded, 4 newly installed, 0 to remove and 128 not upgraded.
Need to get 752 kB of archives.
After this operation, 6.050 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 openssh-sftp-server amd64 1:8.9p1-3ubuntu0.6 [38,7 kB]
Get:2 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 openssh-server amd64 1:8.9p1-3ubuntu0.6 [435 kB]
Get:3 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 ncurses-term all 6.3-2ubuntu0.1 [267 kB]
Get:4 http://archive.ubuntu.com/ubuntu jammy/main amd64 ssh-import-id all 5.11-0ubuntu1 [10,1 kB]
Fetched 752 kB in 1s (922 kB/s)
Preconfiguring packages ...
Selecting previously unselected package openssh-sftp-server.
(Reading database ... 528603 files and directories currently installed.)
Preparing to unpack .../openssh-sftp-server_1%3a8.9p1-3ubuntu0.6_amd64.deb ...
Unpacking openssh-sftp-server (1:8.9p1-3ubuntu0.6) ...
Selecting previously unselected package openssh-server.
Preparing to unpack .../openssh-server_1%3a8.9p1-3ubuntu0.6_amd64.deb ...
Unpacking openssh-server (1:8.9p1-3ubuntu0.6) ...
Selecting previously unselected package ncurses-term.
Preparing to unpack .../ncurses-term_6.3-2ubuntu0.1_all.deb ...
Unpacking ncurses-term (6.3-2ubuntu0.1) ...
Selecting previously unselected package ssh-import-id.
Preparing to unpack .../ssh-import-id_5.11-0ubuntu1_all.deb ...
Unpacking ssh-import-id (5.11-0ubuntu1) ...
Setting up openssh-sftp-server (1:8.9p1-3ubuntu0.6) ...
Setting up openssh-server (1:8.9p1-3ubuntu0.6) ...
Creating config file /etc/ssh/sshd_config with new version
Creating SSH2 RSA key; this may take some time ...
3072 SHA256:JUOQO3hpe8GakUoqXo9RmGOO9fBnx3lb9Amb2gGltjM root@fidenet-OptiPlex-3070 (RSA)
Creating SSH2 ECDSA key; this may take some time ...
256 SHA256:fMsItYJyz595q3UJP0tNE0IeGLluHOiry5rx2rFYEwk root@fidenet-OptiPlex-3070 (ECDSA)
Creating SSH2 ED25519 key; this may take some time ...
256 SHA256:tz+42Pg/g8/h4x86lcuVpk7F+OFOcBV4aUaCgfWcnM8 root@fidenet-OptiPlex-3070 (ED25519)
Created symlink /etc/systemd/system/sshd.service → /lib/systemd/system/ssh.service.
Created symlink /etc/systemd/system/multi-user.target.wants/ssh.service → /lib/systemd/system/ssh.service.
rescue-ssh.target is a disabled or a static unit, not starting it.
ssh.socket is a disabled or a static unit, not starting it.
Setting up ssh-import-id (5.11-0ubuntu1) ...
Setting up ncurses-term (6.3-2ubuntu0.1) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for ufw (0.36.1-4ubuntu0.1) ...
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra/rootfs$ sudo apt-get install openssh-client
openssh-client is already the newest version (1:8.9p1-3ubuntu0.6).
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra/rootfs$ sudo apt upadate
This is the Linux Mint "apt" command.
This commands acts as a wrapper for the APT package manager and many other useful tools such as apt-get, apt-cache, apt-mark, dpkg, aptitude...etc.
It is installed in /usr/local/bin/apt. To use the upstream apt command directly type /usr/bin/apt.
Usage: apt command [options]
apt help command [options]
Commands:
add-repository - Add entries to apt sources.list
autoclean - Erase cache for packages no longer available
autopurge - Erase system-wide config files left by removed packages
autoremove - Remove dependency packages no longer required
build - Build binary or source packages from sources
build-dep - Configure build-dependencies for source packages
changelog - View a package's changelog
check - Verify there are no broken dependencies
clean - Erase downloaded archive files
contains - List packages containing a file
content - List files contained in and installed by a package(s)
deb - Install a local .deb package
depends - Show package dependency information
dist-upgrade - Fully upgrade the system by allowing other package changes
download - Download packages to the current working directory
edit-sources - Edit /etc/apt/sources.list with your preferred text editor
dselect-upgrade - Follow dselect selections
full-upgrade - Same as 'dist-upgrade'
held - List all held packages
help - Show help for a command
hold - Hold a package
install - Install and/or upgrade packages
list - List packages handled by the system (e.g., installed)
policy - Show policy settings
purge - Remove packages and their system-wide configuration files
recommends - List missing recommended packages for a particular package
rdepends - Show reverse dependency information for a package
reinstall - Reinstall packages or install if not yet installed
remove - Remove packages
search - Search for a package by name and/or expression
show - Display detailed information about a package
showhold - Same as 'held'
showsrc - Display source package records matching the given package
source - Download source archives
sources - Same as 'edit-sources'
unhold - Unhold a package
update - Download lists of new/upgradable packages
upgrade - Perform a safe upgrade
version - Show the installed version of a package
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra/rootfs$ sudo apt update
Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
Ign:2 http://packages.linuxmint.com virginia InRelease
Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:4 http://packages.linuxmint.com virginia Release
Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:6 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
128 packages can be upgraded. Run 'apt list --upgradable' to see them.
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra/rootfs$ sudo apt upgrade
Calculating upgrade... Done
linux-headers-5.15.0-101 linux-headers-5.15.0-101-generic
linux-image-5.15.0-101-generic linux-modules-5.15.0-101-generic
linux-modules-extra-5.15.0-101-generic
The following packages will be upgraded:
accountsservice alsa-ucm-conf bash bind9-dnsutils bind9-host bind9-libs
binutils binutils-common binutils-x86-64-linux-gnu cinnamon-control-center
cinnamon-control-center-data cinnamon-control-center-dbg
cinnamon-screensaver cinnamon-session cinnamon-session-common coreutils cups
cups-bsd cups-client cups-common cups-core-drivers cups-daemon
cups-ipp-utils cups-ppdc cups-server-common dns-root-data dnsmasq-base dpkg
dpkg-dev firefox firefox-locale-en firmware-sof-signed
gir1.2-accountsservice-1.0 gir1.2-javascriptcoregtk-4.0
gir1.2-javascriptcoregtk-4.1 gir1.2-webkit2-4.0 gir1.2-webkit2-4.1 iptables
less libaccountsservice0 libbinutils libc-bin libc6 libc6-dbg
libcinnamon-control-center1 libcpanel-json-xs-perl libcscreensaver0
libctf-nobfd0 libctf0 libcups2 libcupsimage2 libde265-0 libdpkg-perl
libegl-mesa0 libexpat1 libgbm1 libgl1-mesa-dri libglapi-mesa libglx-mesa0
libgnutls30 libgpgme11 libgpgmepp6 libip4tc2 libip6tc2
libjavascriptcoregtk-4.0-18 libjavascriptcoregtk-4.1-0 libkpathsea6
libmm-glib0 libnss-myhostname libnvpair3linux libpam-modules
libpam-modules-bin libpam-runtime libpam0g libssh-4 libssh-gcrypt-4 libssl3
libtiff5 libuutil3linux libuv1 libwebkit2gtk-4.0-37 libwebkit2gtk-4.1-0
libxatracker2 libxml2 libxtables12 libzfs4linux libzpool5linux
linux-firmware linux-generic linux-headers-generic linux-image-generic
linux-libc-dev login ltrace mesa-va-drivers mesa-vdpau-drivers
mesa-vulkan-drivers mint-mirrors mint-upgrade-info mintreport mintstick
mintupdate modemmanager openjdk-11-jre openjdk-11-jre-headless openssl
passwd python-apt-common python3-apt python3-cryptography python3-pil
python3-pycryptodome tcpdump transmission-common transmission-gtk tzdata
unzip vim-common vim-tiny xserver-common xserver-xephyr xserver-xorg-core
xserver-xorg-legacy xwayland xxd zfs-initramfs zfs-zed zfsutils-linux
128 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 644 MB of archives.
After this operation, 626 MB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 bash amd64 5.1-6ubuntu1.1 [769 kB]
Get:2 http://packages.linuxmint.com virginia/upstream amd64 firefox amd64 123.0.1+linuxmint1+virginia [73,6 MB]
Get:3 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 coreutils amd64 8.32-4.1ubuntu1.1 [1.436 kB]
Get:4 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 dpkg amd64 1.21.1ubuntu2.3 [1.239 kB]
Get:5 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 login amd64 1:4.8.1-2ubuntu2.2 [188 kB]
Get:6 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libc6-dbg amd64 2.35-0ubuntu3.6 [13,8 MB]
Get:7 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libc6 amd64 2.35-0ubuntu3.6 [3.236 kB]
Get:8 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libc-bin amd64 2.35-0ubuntu3.6 [706 kB]
Get:9 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpam0g amd64 1.4.0-11ubuntu2.4 [60,2 kB]
Get:10 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpam-modules-bin amd64 1.4.0-11ubuntu2.4 [37,6 kB]
Get:11 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpam-modules amd64 1.4.0-11ubuntu2.4 [280 kB]
Get:12 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cups-common all 2.4.1op1-1ubuntu4.8 [253 kB]
Get:13 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cups-ipp-utils amd64 2.4.1op1-1ubuntu4.8 [192 kB]
Get:14 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cups-bsd amd64 2.4.1op1-1ubuntu4.8 [37,0 kB]
Get:15 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cups-client amd64 2.4.1op1-1ubuntu4.8 [127 kB]
Get:16 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cups-core-drivers amd64 2.4.1op1-1ubuntu4.8 [29,1 kB]
Get:17 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cups-server-common all 2.4.1op1-1ubuntu4.8 [401 kB]
Get:18 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cups-ppdc amd64 2.4.1op1-1ubuntu4.8 [97,8 kB]
Get:19 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cups-daemon amd64 2.4.1op1-1ubuntu4.8 [327 kB]
Get:20 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cups amd64 2.4.1op1-1ubuntu4.8 [270 kB]
Get:21 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libcupsimage2 amd64 2.4.1op1-1ubuntu4.8 [6.170 B]
Get:22 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libgnutls30 amd64 3.7.3-4ubuntu1.4 [969 kB]
Get:23 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libcups2 amd64 2.4.1op1-1ubuntu4.8 [264 kB]
Get:24 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 zfs-initramfs amd64 2.1.5-1ubuntu6~22.04.3 [25,0 kB]
Get:25 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 zfsutils-linux amd64 2.1.5-1ubuntu6~22.04.3 [499 kB]
Get:26 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libnvpair3linux amd64 2.1.5-1ubuntu6~22.04.3 [54,9 kB]
Get:27 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libuutil3linux amd64 2.1.5-1ubuntu6~22.04.3 [48,6 kB]
Get:28 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libssl3 amd64 3.0.2-0ubuntu1.15 [1.905 kB]
Get:29 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libzfs4linux amd64 2.1.5-1ubuntu6~22.04.3 [233 kB]
Get:30 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libzpool5linux amd64 2.1.5-1ubuntu6~22.04.3 [1.356 kB]
Get:31 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 zfs-zed amd64 2.1.5-1ubuntu6~22.04.3 [66,7 kB]
Get:32 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpam-runtime all 1.4.0-11ubuntu2.4 [40,3 kB]
Get:33 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 passwd amd64 1:4.8.1-2ubuntu2.2 [768 kB]
Get:34 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libexpat1 amd64 2.4.7-1ubuntu0.3 [91,0 kB]
Get:35 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libxml2 amd64 2.9.13+dfsg-1ubuntu0.4 [763 kB]
Get:36 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 openssl amd64 3.0.2-0ubuntu1.15 [1.186 kB]
Get:37 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 python-apt-common all 2.4.0ubuntu3 [14,6 kB]
Get:38 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 python3-apt amd64 2.4.0ubuntu3 [164 kB]
Get:39 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libssh-4 amd64 0.9.6-2ubuntu0.22.04.3 [186 kB]
Get:40 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libtiff5 amd64 4.3.0-6ubuntu0.8 [185 kB]
Get:41 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 less amd64 590-1ubuntu0.22.04.2 [143 kB]
Get:42 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 iptables amd64 1.8.7-1ubuntu5.2 [455 kB]
Get:43 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libxtables12 amd64 1.8.7-1ubuntu5.2 [31,3 kB]
Get:44 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libip6tc2 amd64 1.8.7-1ubuntu5.2 [20,3 kB]
Get:45 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libip4tc2 amd64 1.8.7-1ubuntu5.2 [19,9 kB]
Get:46 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 tzdata all 2024a-0ubuntu0.22.04 [348 kB]
Get:47 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 vim-tiny amd64 2:8.2.3995-1ubuntu2.16 [710 kB]
Get:48 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 xxd amd64 2:8.2.3995-1ubuntu2.16 [55,0 kB]
Get:49 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 vim-common all 2:8.2.3995-1ubuntu2.16 [81,5 kB]
Get:50 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libuv1 amd64 1.43.0-1ubuntu0.1 [92,7 kB]
Get:51 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 bind9-dnsutils amd64 1:9.18.18-0ubuntu0.22.04.2 [157 kB]
Get:52 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 bind9-host amd64 1:9.18.18-0ubuntu0.22.04.2 [52,5 kB]
Get:53 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 bind9-libs amd64 1:9.18.18-0ubuntu0.22.04.2 [1.245 kB]
Get:54 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 tcpdump amd64 4.99.1-3ubuntu0.2 [501 kB]
Get:55 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 accountsservice amd64 22.07.5-2ubuntu1.5 [70,0 kB]
Get:56 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libaccountsservice0 amd64 22.07.5-2ubuntu1.5 [62,6 kB]
Get:57 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 alsa-ucm-conf all 1.2.6.3-1ubuntu1.11 [43,6 kB]
Get:58 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libctf0 amd64 2.38-4ubuntu2.6 [103 kB]
Get:59 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libctf-nobfd0 amd64 2.38-4ubuntu2.6 [108 kB]
Get:60 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 binutils-x86-64-linux-gnu amd64 2.38-4ubuntu2.6 [2.326 kB]
Get:61 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libbinutils amd64 2.38-4ubuntu2.6 [662 kB]
Get:62 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 binutils amd64 2.38-4ubuntu2.6 [3.200 B]
Get:63 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 binutils-common amd64 2.38-4ubuntu2.6 [222 kB]
Get:64 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libmm-glib0 amd64 1.20.0-1~ubuntu22.04.3 [263 kB]
Get:65 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 dns-root-data all 2023112702~ubuntu0.22.04.1 [5.136 B]
Get:66 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 dnsmasq-base amd64 2.90-0ubuntu0.22.04.1 [374 kB]
Get:67 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 dpkg-dev all 1.21.1ubuntu2.3 [922 kB]
Get:68 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libdpkg-perl all 1.21.1ubuntu2.3 [237 kB]
Get:69 http://archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 firmware-sof-signed all 2.0-1ubuntu4.5 [1.289 kB]
Get:70 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 gir1.2-accountsservice-1.0 amd64 22.07.5-2ubuntu1.5 [5.238 B]
Get:71 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 gir1.2-webkit2-4.0 amd64 2.42.5-0ubuntu0.22.04.2 [103 kB]
Get:72 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 gir1.2-javascriptcoregtk-4.0 amd64 2.42.5-0ubuntu0.22.04.2 [38,1 kB]
Get:73 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libwebkit2gtk-4.0-37 amd64 2.42.5-0ubuntu0.22.04.2 [21,7 MB]
Get:74 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libjavascriptcoregtk-4.0-18 amd64 2.42.5-0ubuntu0.22.04.2 [8.127 kB]
Get:75 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 xserver-common all 2:21.1.4-2ubuntu1.7~22.04.8 [28,6 kB]
Get:76 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 xserver-xorg-legacy amd64 2:21.1.4-2ubuntu1.7~22.04.8 [35,3 kB]
Get:77 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 xserver-xorg-core amd64 2:21.1.4-2ubuntu1.7~22.04.8 [1.477 kB]
Get:78 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libgl1-mesa-dri amd64 23.2.1-1ubuntu3.1~22.04.2 [8.860 kB]
Get:79 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libglx-mesa0 amd64 23.2.1-1ubuntu3.1~22.04.2 [158 kB]
Get:80 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libegl-mesa0 amd64 23.2.1-1ubuntu3.1~22.04.2 [118 kB]
Get:81 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libglapi-mesa amd64 23.2.1-1ubuntu3.1~22.04.2 [37,1 kB]
Get:82 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libgbm1 amd64 23.2.1-1ubuntu3.1~22.04.2 [33,5 kB]
Get:83 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 gir1.2-webkit2-4.1 amd64 2.42.5-0ubuntu0.22.04.2 [104 kB]
Get:84 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 gir1.2-javascriptcoregtk-4.1 amd64 2.42.5-0ubuntu0.22.04.2 [38,1 kB]
Get:85 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 libwebkit2gtk-4.1-0 amd64 2.42.5-0ubuntu0.22.04.2 [21,7 MB]
Get:86 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libjavascriptcoregtk-4.1-0 amd64 2.42.5-0ubuntu0.22.04.2 [8.127 kB]
Get:87 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libcpanel-json-xs-perl amd64 4.27-1ubuntu0.1 [115 kB]
Get:88 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 libde265-0 amd64 1.0.8-1ubuntu0.3 [290 kB]
Get:89 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libgpgme11 amd64 1.16.0-1.2ubuntu4.2 [136 kB]
Get:90 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libgpgmepp6 amd64 1.16.0-1.2ubuntu4.2 [109 kB]
Get:91 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libkpathsea6 amd64 2021.20210626.59705-1ubuntu0.2 [60,4 kB]
Get:92 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libssh-gcrypt-4 amd64 0.9.6-2ubuntu0.22.04.3 [223 kB]
Get:93 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libxatracker2 amd64 23.2.1-1ubuntu3.1~22.04.2 [2.112 kB]
Get:94 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-firmware all 20220329.git681281e4-0ubuntu3.29 [267 MB]
Get:95 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-modules-5.15.0-101-generic amd64 5.15.0-101.111 [22,6 MB]
Get:96 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-image-5.15.0-101-generic amd64 5.15.0-101.111 [11,5 MB]
Get:97 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-modules-extra-5.15.0-101-generic amd64 5.15.0-101.111 [63,9 MB]
Get:98 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-generic amd64 5.15.0.101.98 [1.698 B]
Get:99 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-image-generic amd64 5.15.0.101.98 [2.486 B]
Get:100 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-headers-5.15.0-101 all 5.15.0-101.111 [12,3 MB]
Get:101 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-headers-5.15.0-101-generic amd64 5.15.0-101.111 [2.876 kB]
Get:102 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-headers-generic amd64 5.15.0.101.98 [2.332 B]
Get:103 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-libc-dev amd64 5.15.0-101.111 [1.333 kB]
Get:104 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 ltrace amd64 0.7.3-6.1ubuntu6.22.04.1 [133 kB]
Get:105 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 mesa-va-drivers amd64 23.2.1-1ubuntu3.1~22.04.2 [4.100 kB]
Get:106 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 mesa-vdpau-drivers amd64 23.2.1-1ubuntu3.1~22.04.2 [3.820 kB]
Get:107 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 mesa-vulkan-drivers amd64 23.2.1-1ubuntu3.1~22.04.2 [10,7 MB]
Get:108 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 modemmanager amd64 1.20.0-1~ubuntu22.04.3 [1.094 kB]
Get:109 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 openjdk-11-jre amd64 11.0.22+7-0ubuntu2~22.04.1 [214 kB]
Get:110 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 openjdk-11-jre-headless amd64 11.0.22+7-0ubuntu2~22.04.1 [42,5 MB]
Get:111 http://packages.linuxmint.com virginia/backport amd64 cinnamon-control-center-dbg amd64 6.0.1+virginia [1.156 kB]
Get:112 http://packages.linuxmint.com virginia/backport amd64 cinnamon-control-center amd64 6.0.1+virginia [264 kB]
Get:113 http://packages.linuxmint.com virginia/backport amd64 cinnamon-control-center-data all 6.0.1+virginia [1.504 kB]
Get:114 http://packages.linuxmint.com virginia/backport amd64 libcinnamon-control-center1 amd64 6.0.1+virginia [13,2 kB]
Get:115 http://packages.linuxmint.com virginia/backport amd64 cinnamon-screensaver amd64 6.0.3+virginia [79,7 kB]
Get:116 http://packages.linuxmint.com virginia/backport amd64 libcscreensaver0 amd64 6.0.3+virginia [122 kB]
Get:117 http://packages.linuxmint.com virginia/backport amd64 cinnamon-session amd64 6.0.4+virginia [101 kB]
Get:118 http://packages.linuxmint.com virginia/backport amd64 cinnamon-session-common all 6.0.4+virginia [17,5 kB]
Get:119 http://packages.linuxmint.com virginia/upstream amd64 firefox-locale-en amd64 123.0.1+linuxmint1+virginia [824 kB]
Get:120 http://packages.linuxmint.com virginia/main amd64 mint-mirrors all 1.2.6 [6.124 B]
Get:121 http://packages.linuxmint.com virginia/main amd64 mint-upgrade-info all 1.2.6 [656 kB]
Get:122 http://packages.linuxmint.com virginia/main amd64 mintreport all 1.4.7 [193 kB]
Get:123 http://packages.linuxmint.com virginia/main amd64 mintstick all 1.6.0 [52,0 kB]
Get:124 http://packages.linuxmint.com virginia/main amd64 mintupdate all 6.0.9 [664 kB]
Get:125 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 python3-cryptography amd64 3.4.8-1ubuntu2.2 [236 kB]
Get:126 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 python3-pil amd64 9.0.1-1ubuntu0.2 [419 kB]
Get:127 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 python3-pycryptodome amd64 3.11.0+dfsg1-3ubuntu0.1 [1.029 kB]
Get:128 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 transmission-common all 3.00-2ubuntu2.1 [205 kB]
Get:129 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 transmission-gtk amd64 3.00-2ubuntu2.1 [412 kB]
Get:130 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 unzip amd64 6.0-26ubuntu3.2 [175 kB]
Get:131 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 xserver-xephyr amd64 2:21.1.4-2ubuntu1.7~22.04.8 [1.014 kB]
Get:132 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 xwayland amd64 2:22.1.1-1ubuntu0.11 [934 kB]
Get:133 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 libnss-myhostname amd64 249.11-0ubuntu3.12 [54,9 kB]
Fetched 644 MB in 2min 1s (5.302 kB/s)
Extracting templates from packages: 100%
setting xserver-xorg-legacy/xwrapper/allowed_users from configuration file
(Reading database ... 531479 files and directories currently installed.)
Preparing to unpack .../bash_5.1-6ubuntu1.1_amd64.deb ...
Unpacking bash (5.1-6ubuntu1.1) over (5.1-6ubuntu1) ...
Setting up bash (5.1-6ubuntu1.1) ...
update-alternatives: using /usr/share/man/man7/bash-builtins.7.gz to provide /us
r/share/man/man7/builtins.7.gz (builtins.7.gz) in auto mode
Preparing to unpack .../coreutils_8.32-4.1ubuntu1.1_amd64.deb ...
Unpacking coreutils (8.32-4.1ubuntu1.1) over (8.32-4.1ubuntu1) ...
Setting up coreutils (8.32-4.1ubuntu1.1) ...
Preparing to unpack .../dpkg_1.21.1ubuntu2.3_amd64.deb ...
Unpacking dpkg (1.21.1ubuntu2.3) over (1.21.1ubuntu2.2) ...
Setting up dpkg (1.21.1ubuntu2.3) ...
dpkg-db-backup.service is a disabled or a static unit not running, not starting
it.
Preparing to unpack .../login_1%3a4.8.1-2ubuntu2.2_amd64.deb ...
Unpacking login (1:4.8.1-2ubuntu2.2) over (1:4.8.1-2ubuntu2.1) ...
Setting up login (1:4.8.1-2ubuntu2.2) ...
Preparing to unpack .../libc6-dbg_2.35-0ubuntu3.6_amd64.deb ...
Unpacking libc6-dbg:amd64 (2.35-0ubuntu3.6) over (2.35-0ubuntu3.5) ...
Preparing to unpack .../libc6_2.35-0ubuntu3.6_amd64.deb ...
Unpacking libc6:amd64 (2.35-0ubuntu3.6) over (2.35-0ubuntu3.5) ...
Setting up libc6:amd64 (2.35-0ubuntu3.6) ...
(Reading database ... 531483 files and directories currently installed.)
Preparing to unpack .../libc-bin_2.35-0ubuntu3.6_amd64.deb ...
Unpacking libc-bin (2.35-0ubuntu3.6) over (2.35-0ubuntu3.5) ...
Setting up libc-bin (2.35-0ubuntu3.6) ...
Preparing to unpack .../libpam0g_1.4.0-11ubuntu2.4_amd64.deb ...
Unpacking libpam0g:amd64 (1.4.0-11ubuntu2.4) over (1.4.0-11ubuntu2.3) ...
Setting up libpam0g:amd64 (1.4.0-11ubuntu2.4) ...
Preparing to unpack .../libpam-modules-bin_1.4.0-11ubuntu2.4_amd64.deb ...
Unpacking libpam-modules-bin (1.4.0-11ubuntu2.4) over (1.4.0-11ubuntu2.3) ...
Setting up libpam-modules-bin (1.4.0-11ubuntu2.4) ...
Preparing to unpack .../libpam-modules_1.4.0-11ubuntu2.4_amd64.deb ...
Unpacking libpam-modules:amd64 (1.4.0-11ubuntu2.4) over (1.4.0-11ubuntu2.3) ...
Setting up libpam-modules:amd64 (1.4.0-11ubuntu2.4) ...
Preparing to unpack .../00-cups-common_2.4.1op1-1ubuntu4.8_all.deb ...
Unpacking cups-common (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ...
Preparing to unpack .../01-cups-ipp-utils_2.4.1op1-1ubuntu4.8_amd64.deb ...
Unpacking cups-ipp-utils (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ...
Preparing to unpack .../02-cups-bsd_2.4.1op1-1ubuntu4.8_amd64.deb ...
Unpacking cups-bsd (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ...
Preparing to unpack .../03-cups-client_2.4.1op1-1ubuntu4.8_amd64.deb ...
Unpacking cups-client (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ...
Preparing to unpack .../04-cups-core-drivers_2.4.1op1-1ubuntu4.8_amd64.deb ...
Unpacking cups-core-drivers (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ...
Preparing to unpack .../05-cups-server-common_2.4.1op1-1ubuntu4.8_all.deb ...
Unpacking cups-server-common (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ..
Preparing to unpack .../06-cups-ppdc_2.4.1op1-1ubuntu4.8_amd64.deb ...
Unpacking cups-ppdc (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ...
Preparing to unpack .../07-cups-daemon_2.4.1op1-1ubuntu4.8_amd64.deb ...
Unpacking cups-daemon (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ...
Preparing to unpack .../08-cups_2.4.1op1-1ubuntu4.8_amd64.deb ...
Unpacking cups (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ...
Preparing to unpack .../09-libcupsimage2_2.4.1op1-1ubuntu4.8_amd64.deb ...
Unpacking libcupsimage2:amd64 (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) .
Preparing to unpack .../10-libgnutls30_3.7.3-4ubuntu1.4_amd64.deb ...
Unpacking libgnutls30:amd64 (3.7.3-4ubuntu1.4) over (3.7.3-4ubuntu1.3) ...
Setting up libgnutls30:amd64 (3.7.3-4ubuntu1.4) ...
Preparing to unpack .../libcups2_2.4.1op1-1ubuntu4.8_amd64.deb ...
Unpacking libcups2:amd64 (2.4.1op1-1ubuntu4.8) over (2.4.1op1-1ubuntu4.7) ...
Setting up libcups2:amd64 (2.4.1op1-1ubuntu4.8) ...
Preparing to unpack .../0-firefox_123.0.1+linuxmint1+virginia_amd64.deb ...
Unpacking firefox (123.0.1+linuxmint1+virginia) over (121.0+linuxmint1+virginia)
Preparing to unpack .../1-zfs-initramfs_2.1.5-1ubuntu6~22.04.3_amd64.deb ...
Unpacking zfs-initramfs (2.1.5-1ubuntu6~22.04.3) over (2.1.5-1ubuntu6~22.04.2) .
Preparing to unpack .../2-zfsutils-linux_2.1.5-1ubuntu6~22.04.3_amd64.deb ...
Unpacking zfsutils-linux (2.1.5-1ubuntu6~22.04.3) over (2.1.5-1ubuntu6~22.04.2)
Preparing to unpack .../3-libnvpair3linux_2.1.5-1ubuntu6~22.04.3_amd64.deb ...
Unpacking libnvpair3linux (2.1.5-1ubuntu6~22.04.3) over (2.1.5-1ubuntu6~22.04.2)
Preparing to unpack .../4-libuutil3linux_2.1.5-1ubuntu6~22.04.3_amd64.deb ...
Unpacking libuutil3linux (2.1.5-1ubuntu6~22.04.3) over (2.1.5-1ubuntu6~22.04.2)
Preparing to unpack .../5-libssl3_3.0.2-0ubuntu1.15_amd64.deb ...
Unpacking libssl3:amd64 (3.0.2-0ubuntu1.15) over (3.0.2-0ubuntu1.12) ...
Setting up libssl3:amd64 (3.0.2-0ubuntu1.15) ...
Preparing to unpack .../libzfs4linux_2.1.5-1ubuntu6~22.04.3_amd64.deb ...
Unpacking libzfs4linux (2.1.5-1ubuntu6~22.04.3) over (2.1.5-1ubuntu6~22.04.2) ..
Preparing to unpack .../libzpool5linux_2.1.5-1ubuntu6~22.04.3_amd64.deb ...
Unpacking libzpool5linux (2.1.5-1ubuntu6~22.04.3) over (2.1.5-1ubuntu6~22.04.2)
Preparing to unpack .../zfs-zed_2.1.5-1ubuntu6~22.04.3_amd64.deb ...
Unpacking zfs-zed (2.1.5-1ubuntu6~22.04.3) over (2.1.5-1ubuntu6~22.04.2) ...
Preparing to unpack .../libpam-runtime_1.4.0-11ubuntu2.4_all.deb ...
Unpacking libpam-runtime (1.4.0-11ubuntu2.4) over (1.4.0-11ubuntu2.3) ...
Setting up libpam-runtime (1.4.0-11ubuntu2.4) ...
Preparing to unpack .../passwd_1%3a4.8.1-2ubuntu2.2_amd64.deb ...
Unpacking passwd (1:4.8.1-2ubuntu2.2) over (1:4.8.1-2ubuntu2.1) ...
Setting up passwd (1:4.8.1-2ubuntu2.2) ...
Preparing to unpack .../libexpat1_2.4.7-1ubuntu0.3_amd64.deb ...
Unpacking libexpat1:amd64 (2.4.7-1ubuntu0.3) over (2.4.7-1ubuntu0.2) ...
Setting up libexpat1:amd64 (2.4.7-1ubuntu0.3) ...
Preparing to unpack .../libxml2_2.9.13+dfsg-1ubuntu0.4_amd64.deb ...
Unpacking libxml2:amd64 (2.9.13+dfsg-1ubuntu0.4) over (2.9.13+dfsg-1ubuntu0.3) .
Setting up libxml2:amd64 (2.9.13+dfsg-1ubuntu0.4) ...
Preparing to unpack .../openssl_3.0.2-0ubuntu1.15_amd64.deb ...
Unpacking openssl (3.0.2-0ubuntu1.15) over (3.0.2-0ubuntu1.12) ...
Setting up openssl (3.0.2-0ubuntu1.15) ...
Preparing to unpack .../python-apt-common_2.4.0ubuntu3_all.deb ...
Unpacking python-apt-common (2.4.0ubuntu3) over (2.4.0ubuntu2) ...
Setting up python-apt-common (2.4.0ubuntu3) ...
Preparing to unpack .../python3-apt_2.4.0ubuntu3_amd64.deb ...
Unpacking python3-apt (2.4.0ubuntu3) over (2.4.0ubuntu2) ...
Setting up python3-apt (2.4.0ubuntu3) ...
Preparing to unpack .../libssh-4_0.9.6-2ubuntu0.22.04.3_amd64.deb ...
Unpacking libssh-4:amd64 (0.9.6-2ubuntu0.22.04.3) over (0.9.6-2ubuntu0.22.04.2)
Setting up libssh-4:amd64 (0.9.6-2ubuntu0.22.04.3) ...
Preparing to unpack .../libtiff5_4.3.0-6ubuntu0.8_amd64.deb ...
Unpacking libtiff5:amd64 (4.3.0-6ubuntu0.8) over (4.3.0-6ubuntu0.7) ...
Setting up libtiff5:amd64 (4.3.0-6ubuntu0.8) ...
Preparing to unpack .../00-less_590-1ubuntu0.22.04.2_amd64.deb ...
Unpacking less (590-1ubuntu0.22.04.2) over (590-1ubuntu0.22.04.1) ...
Preparing to unpack .../01-iptables_1.8.7-1ubuntu5.2_amd64.deb ...
Unpacking iptables (1.8.7-1ubuntu5.2) over (1.8.7-1ubuntu5.1) ...
Preparing to unpack .../02-libxtables12_1.8.7-1ubuntu5.2_amd64.deb ...
Unpacking libxtables12:amd64 (1.8.7-1ubuntu5.2) over (1.8.7-1ubuntu5.1) ...
Preparing to unpack .../03-libip6tc2_1.8.7-1ubuntu5.2_amd64.deb ...
Unpacking libip6tc2:amd64 (1.8.7-1ubuntu5.2) over (1.8.7-1ubuntu5.1) ...
Preparing to unpack .../04-libip4tc2_1.8.7-1ubuntu5.2_amd64.deb ...
Unpacking libip4tc2:amd64 (1.8.7-1ubuntu5.2) over (1.8.7-1ubuntu5.1) ...
Preparing to unpack .../05-tzdata_2024a-0ubuntu0.22.04_all.deb ...
Unpacking tzdata (2024a-0ubuntu0.22.04) over (2023c-0ubuntu0.22.04.2) ...
Preparing to unpack .../06-vim-tiny_2%3a8.2.3995-1ubuntu2.16_amd64.deb ...
Unpacking vim-tiny (2:8.2.3995-1ubuntu2.16) over (2:8.2.3995-1ubuntu2.15) ...
Preparing to unpack .../07-xxd_2%3a8.2.3995-1ubuntu2.16_amd64.deb ...
Unpacking xxd (2:8.2.3995-1ubuntu2.16) over (2:8.2.3995-1ubuntu2.15) ...
Preparing to unpack .../08-vim-common_2%3a8.2.3995-1ubuntu2.16_all.deb ...
Unpacking vim-common (2:8.2.3995-1ubuntu2.16) over (2:8.2.3995-1ubuntu2.15) ...
Preparing to unpack .../09-libuv1_1.43.0-1ubuntu0.1_amd64.deb ...
Unpacking libuv1:amd64 (1.43.0-1ubuntu0.1) over (1.43.0-1) ...
Preparing to unpack .../10-bind9-dnsutils_1%3a9.18.18-0ubuntu0.22.04.2_amd64.deb
Unpacking bind9-dnsutils (1:9.18.18-0ubuntu0.22.04.2) over (1:9.18.18-0ubuntu0.2
2.04.1) ...
Preparing to unpack .../11-bind9-host_1%3a9.18.18-0ubuntu0.22.04.2_amd64.deb ...
Unpacking bind9-host (1:9.18.18-0ubuntu0.22.04.2) over (1:9.18.18-0ubuntu0.22.04
.1) ...
Preparing to unpack .../12-bind9-libs_1%3a9.18.18-0ubuntu0.22.04.2_amd64.deb ...
Unpacking bind9-libs:amd64 (1:9.18.18-0ubuntu0.22.04.2) over (1:9.18.18-0ubuntu0
.22.04.1) ...
Preparing to unpack .../13-tcpdump_4.99.1-3ubuntu0.2_amd64.deb ...
Unpacking tcpdump (4.99.1-3ubuntu0.2) over (4.99.1-3ubuntu0.1) ...
Preparing to unpack .../14-accountsservice_22.07.5-2ubuntu1.5_amd64.deb ...
Unpacking accountsservice (22.07.5-2ubuntu1.5) over (22.07.5-2ubuntu1.4) ...
Preparing to unpack .../15-libaccountsservice0_22.07.5-2ubuntu1.5_amd64.deb ...
Unpacking libaccountsservice0:amd64 (22.07.5-2ubuntu1.5) over (22.07.5-2ubuntu1.
4) ...
Preparing to unpack .../16-alsa-ucm-conf_1.2.6.3-1ubuntu1.11_all.deb ...
Unpacking alsa-ucm-conf (1.2.6.3-1ubuntu1.11) over (1.2.6.3-1ubuntu1.9) ...
Preparing to unpack .../17-libctf0_2.38-4ubuntu2.6_amd64.deb ...
Unpacking libctf0:amd64 (2.38-4ubuntu2.6) over (2.38-4ubuntu2.4) ...
Preparing to unpack .../18-libctf-nobfd0_2.38-4ubuntu2.6_amd64.deb ...
Unpacking libctf-nobfd0:amd64 (2.38-4ubuntu2.6) over (2.38-4ubuntu2.4) ...
Preparing to unpack .../19-binutils-x86-64-linux-gnu_2.38-4ubuntu2.6_amd64.deb .
Unpacking binutils-x86-64-linux-gnu (2.38-4ubuntu2.6) over (2.38-4ubuntu2.4) ...
Preparing to unpack .../20-libbinutils_2.38-4ubuntu2.6_amd64.deb ...
Unpacking libbinutils:amd64 (2.38-4ubuntu2.6) over (2.38-4ubuntu2.4) ...
Preparing to unpack .../21-binutils_2.38-4ubuntu2.6_amd64.deb ...
Unpacking binutils (2.38-4ubuntu2.6) over (2.38-4ubuntu2.4) ...
Preparing to unpack .../22-binutils-common_2.38-4ubuntu2.6_amd64.deb ...
Unpacking binutils-common:amd64 (2.38-4ubuntu2.6) over (2.38-4ubuntu2.4) ...
Preparing to unpack .../23-cinnamon-control-center-dbg_6.0.1+virginia_amd64.deb
Unpacking cinnamon-control-center-dbg (6.0.1+virginia) over (6.0.0+virginia) ...
Preparing to unpack .../24-cinnamon-control-center_6.0.1+virginia_amd64.deb ...
Unpacking cinnamon-control-center (6.0.1+virginia) over (6.0.0+virginia) ...
Preparing to unpack .../25-cinnamon-control-center-data_6.0.1+virginia_all.deb .
Unpacking cinnamon-control-center-data (6.0.1+virginia) over (6.0.0+virginia) ..
Preparing to unpack .../26-libcinnamon-control-center1_6.0.1+virginia_amd64.deb
Unpacking libcinnamon-control-center1:amd64 (6.0.1+virginia) over (6.0.0+virgini
a) ...
Preparing to unpack .../27-libmm-glib0_1.20.0-1~ubuntu22.04.3_amd64.deb ...
Unpacking libmm-glib0:amd64 (1.20.0-1~ubuntu22.04.3) over (1.20.0-1~ubuntu22.04.
2) ...
Preparing to unpack .../28-cinnamon-screensaver_6.0.3+virginia_amd64.deb ...
Unpacking cinnamon-screensaver (6.0.3+virginia) over (6.0.2+virginia) ...
Preparing to unpack .../29-libcscreensaver0_6.0.3+virginia_amd64.deb ...
Unpacking libcscreensaver0:amd64 (6.0.3+virginia) over (6.0.2+virginia) ...
Preparing to unpack .../30-cinnamon-session_6.0.4+virginia_amd64.deb ...
Unpacking cinnamon-session (6.0.4+virginia) over (6.0.1+virginia) ...
Preparing to unpack .../31-cinnamon-session-common_6.0.4+virginia_all.deb ...
Unpacking cinnamon-session-common (6.0.4+virginia) over (6.0.1+virginia) ...
Preparing to unpack .../32-dns-root-data_2023112702~ubuntu0.22.04.1_all.deb ...
Unpacking dns-root-data (2023112702~ubuntu0.22.04.1) over (2021011101) ...
Preparing to unpack .../33-dnsmasq-base_2.90-0ubuntu0.22.04.1_amd64.deb ...
Unpacking dnsmasq-base (2.90-0ubuntu0.22.04.1) over (2.86-1.1ubuntu0.3) ...
Preparing to unpack .../34-dpkg-dev_1.21.1ubuntu2.3_all.deb ...
Unpacking dpkg-dev (1.21.1ubuntu2.3) over (1.21.1ubuntu2.2) ...
Preparing to unpack .../35-libdpkg-perl_1.21.1ubuntu2.3_all.deb ...
Unpacking libdpkg-perl (1.21.1ubuntu2.3) over (1.21.1ubuntu2.2) ...
Preparing to unpack .../36-firefox-locale-en_123.0.1+linuxmint1+virginia_amd64.d
eb ...
Unpacking firefox-locale-en (123.0.1+linuxmint1+virginia) over (121.0+linuxmint1
+virginia) ...
Preparing to unpack .../37-firmware-sof-signed_2.0-1ubuntu4.5_all.deb ...
Unpacking firmware-sof-signed (2.0-1ubuntu4.5) over (2.0-1ubuntu4.4) ...
Preparing to unpack .../38-gir1.2-accountsservice-1.0_22.07.5-2ubuntu1.5_amd64.d
eb ...
Unpacking gir1.2-accountsservice-1.0:amd64 (22.07.5-2ubuntu1.5) over (22.07.5-2u
buntu1.4) ...
Preparing to unpack .../39-gir1.2-webkit2-4.0_2.42.5-0ubuntu0.22.04.2_amd64.deb
Unpacking gir1.2-webkit2-4.0:amd64 (2.42.5-0ubuntu0.22.04.2) over (2.42.3-0ubunt
u0.22.04.1) ...
Preparing to unpack .../40-gir1.2-javascriptcoregtk-4.0_2.42.5-0ubuntu0.22.04.2_
amd64.deb ...
Unpacking gir1.2-javascriptcoregtk-4.0:amd64 (2.42.5-0ubuntu0.22.04.2) over (2.4
2.3-0ubuntu0.22.04.1) ...
Preparing to unpack .../41-libwebkit2gtk-4.0-37_2.42.5-0ubuntu0.22.04.2_amd64.de
b ...
Unpacking libwebkit2gtk-4.0-37:amd64 (2.42.5-0ubuntu0.22.04.2) over (2.42.3-0ubu
ntu0.22.04.1) ...
Preparing to unpack .../42-libjavascriptcoregtk-4.0-18_2.42.5-0ubuntu0.22.04.2_a
md64.deb ...
Unpacking libjavascriptcoregtk-4.0-18:amd64 (2.42.5-0ubuntu0.22.04.2) over (2.42
Preparing to unpack .../43-xserver-common_2%3a21.1.4-2ubuntu1.7~22.04.8_all.deb
Unpacking xserver-common (2:21.1.4-2ubuntu1.7~22.04.8) over (2:21.1.4-2ubuntu1.7
~22.04.5) ...
Preparing to unpack .../44-xserver-xorg-legacy_2%3a21.1.4-2ubuntu1.7~22.04.8_amd
64.deb ...
Unpacking xserver-xorg-legacy (2:21.1.4-2ubuntu1.7~22.04.8) over (2:21.1.4-2ubun
tu1.7~22.04.5) ...
Preparing to unpack .../45-xserver-xorg-core_2%3a21.1.4-2ubuntu1.7~22.04.8_amd64
.deb ...
Unpacking xserver-xorg-core (2:21.1.4-2ubuntu1.7~22.04.8) over (2:21.1.4-2ubuntu
1.7~22.04.5) ...
Preparing to unpack .../46-libgl1-mesa-dri_23.2.1-1ubuntu3.1~22.04.2_amd64.deb .
Unpacking libgl1-mesa-dri:amd64 (23.2.1-1ubuntu3.1~22.04.2) over (23.0.4-0ubuntu
1~22.04.1) ...
Preparing to unpack .../47-libglx-mesa0_23.2.1-1ubuntu3.1~22.04.2_amd64.deb ...
Unpacking libglx-mesa0:amd64 (23.2.1-1ubuntu3.1~22.04.2) over (23.0.4-0ubuntu1~2
2.04.1) ...
Preparing to unpack .../48-libegl-mesa0_23.2.1-1ubuntu3.1~22.04.2_amd64.deb ...
Unpacking libegl-mesa0:amd64 (23.2.1-1ubuntu3.1~22.04.2) over (23.0.4-0ubuntu1~2
2.04.1) ...
Preparing to unpack .../49-libglapi-mesa_23.2.1-1ubuntu3.1~22.04.2_amd64.deb ...
Unpacking libglapi-mesa:amd64 (23.2.1-1ubuntu3.1~22.04.2) over (23.0.4-0ubuntu1~
22.04.1) ...
Preparing to unpack .../50-libgbm1_23.2.1-1ubuntu3.1~22.04.2_amd64.deb ...
Unpacking libgbm1:amd64 (23.2.1-1ubuntu3.1~22.04.2) over (23.0.4-0ubuntu1~22.04.
1) ...
Preparing to unpack .../51-gir1.2-webkit2-4.1_2.42.5-0ubuntu0.22.04.2_amd64.deb
Unpacking gir1.2-webkit2-4.1:amd64 (2.42.5-0ubuntu0.22.04.2) over (2.42.3-0ubunt
u0.22.04.1) ...
Preparing to unpack .../52-gir1.2-javascriptcoregtk-4.1_2.42.5-0ubuntu0.22.04.2_
amd64.deb ...
Unpacking gir1.2-javascriptcoregtk-4.1:amd64 (2.42.5-0ubuntu0.22.04.2) over (2.4
Preparing to unpack .../53-libwebkit2gtk-4.1-0_2.42.5-0ubuntu0.22.04.2_amd64.deb
Unpacking libwebkit2gtk-4.1-0:amd64 (2.42.5-0ubuntu0.22.04.2) over (2.42.3-0ubun
tu0.22.04.1) ...
Preparing to unpack .../54-libjavascriptcoregtk-4.1-0_2.42.5-0ubuntu0.22.04.2_am
d64.deb ...
Unpacking libjavascriptcoregtk-4.1-0:amd64 (2.42.5-0ubuntu0.22.04.2) over (2.42.
Preparing to unpack .../55-libcpanel-json-xs-perl_4.27-1ubuntu0.1_amd64.deb ...
Unpacking libcpanel-json-xs-perl:amd64 (4.27-1ubuntu0.1) over (4.27-1build1) ...
Preparing to unpack .../56-libde265-0_1.0.8-1ubuntu0.3_amd64.deb ...
Unpacking libde265-0:amd64 (1.0.8-1ubuntu0.3) over (1.0.8-1) ...
Preparing to unpack .../57-libgpgme11_1.16.0-1.2ubuntu4.2_amd64.deb ...
Unpacking libgpgme11:amd64 (1.16.0-1.2ubuntu4.2) over (1.16.0-1.2ubuntu4.1) ...
Preparing to unpack .../58-libgpgmepp6_1.16.0-1.2ubuntu4.2_amd64.deb ...
Unpacking libgpgmepp6:amd64 (1.16.0-1.2ubuntu4.2) over (1.16.0-1.2ubuntu4.1) ...
Preparing to unpack .../59-libkpathsea6_2021.20210626.59705-1ubuntu0.2_amd64.deb
Unpacking libkpathsea6:amd64 (2021.20210626.59705-1ubuntu0.2) over (2021.2021062
6.59705-1ubuntu0.1) ...
Preparing to unpack .../60-libssh-gcrypt-4_0.9.6-2ubuntu0.22.04.3_amd64.deb ...
Unpacking libssh-gcrypt-4:amd64 (0.9.6-2ubuntu0.22.04.3) over (0.9.6-2ubuntu0.22
.04.2) ...
Preparing to unpack .../61-libxatracker2_23.2.1-1ubuntu3.1~22.04.2_amd64.deb ...
Unpacking libxatracker2:amd64 (23.2.1-1ubuntu3.1~22.04.2) over (23.0.4-0ubuntu1~
22.04.1) ...
Preparing to unpack .../62-linux-firmware_20220329.git681281e4-0ubuntu3.29_all.d
eb ...
Unpacking linux-firmware (20220329.git681281e4-0ubuntu3.29) over (20220329.git68
1281e4-0ubuntu3.24) ...
Selecting previously unselected package linux-modules-5.15.0-101-generic.
Preparing to unpack .../63-linux-modules-5.15.0-101-generic_5.15.0-101.111_amd64
.deb ...
Unpacking linux-modules-5.15.0-101-generic (5.15.0-101.111) ...
Selecting previously unselected package linux-image-5.15.0-101-generic.
Preparing to unpack .../64-linux-image-5.15.0-101-generic_5.15.0-101.111_amd64.d
eb ...
Unpacking linux-image-5.15.0-101-generic (5.15.0-101.111) ...
Selecting previously unselected package linux-modules-extra-5.15.0-101-generic.
Preparing to unpack .../65-linux-modules-extra-5.15.0-101-generic_5.15.0-101.111
_amd64.deb ...
Unpacking linux-modules-extra-5.15.0-101-generic (5.15.0-101.111) ...
Preparing to unpack .../66-linux-generic_5.15.0.101.98_amd64.deb ...
Unpacking linux-generic (5.15.0.101.98) over (5.15.0.91.88) ...
Preparing to unpack .../67-linux-image-generic_5.15.0.101.98_amd64.deb ...
Unpacking linux-image-generic (5.15.0.101.98) over (5.15.0.91.88) ...
Selecting previously unselected package linux-headers-5.15.0-101.
Preparing to unpack .../68-linux-headers-5.15.0-101_5.15.0-101.111_all.deb ...
Unpacking linux-headers-5.15.0-101 (5.15.0-101.111) ...
Selecting previously unselected package linux-headers-5.15.0-101-generic.
Preparing to unpack .../69-linux-headers-5.15.0-101-generic_5.15.0-101.111_amd64
.deb ...
Unpacking linux-headers-5.15.0-101-generic (5.15.0-101.111) ...
Preparing to unpack .../70-linux-headers-generic_5.15.0.101.98_amd64.deb ...
Unpacking linux-headers-generic (5.15.0.101.98) over (5.15.0.91.88) ...
Preparing to unpack .../71-linux-libc-dev_5.15.0-101.111_amd64.deb ...
Unpacking linux-libc-dev:amd64 (5.15.0-101.111) over (5.15.0-91.101) ...
Preparing to unpack .../72-ltrace_0.7.3-6.1ubuntu6.22.04.1_amd64.deb ...
Unpacking ltrace (0.7.3-6.1ubuntu6.22.04.1) over (0.7.3-6.1ubuntu6) ...
Preparing to unpack .../73-mesa-va-drivers_23.2.1-1ubuntu3.1~22.04.2_amd64.deb .
Unpacking mesa-va-drivers:amd64 (23.2.1-1ubuntu3.1~22.04.2) over (23.0.4-0ubuntu
1~22.04.1) ...
Preparing to unpack .../74-mesa-vdpau-drivers_23.2.1-1ubuntu3.1~22.04.2_amd64.de
b ...
Unpacking mesa-vdpau-drivers:amd64 (23.2.1-1ubuntu3.1~22.04.2) over (23.0.4-0ubu
ntu1~22.04.1) ...
Preparing to unpack .../75-mesa-vulkan-drivers_23.2.1-1ubuntu3.1~22.04.2_amd64.d
eb ...
Unpacking mesa-vulkan-drivers:amd64 (23.2.1-1ubuntu3.1~22.04.2) over (23.0.4-0ub
untu1~22.04.1) ...
Preparing to unpack .../76-mint-mirrors_1.2.6_all.deb ...
Unpacking mint-mirrors (1.2.6) over (1.2.5) ...
Preparing to unpack .../77-mint-upgrade-info_1.2.6_all.deb ...
Removing previous content in /usr/share/mint-upgrade-info...
Unpacking mint-upgrade-info (1.2.6) over (1.2.3) ...
Preparing to unpack .../78-mintreport_1.4.7_all.deb ...
Unpacking mintreport (1.4.7) over (1.4.6) ...
Preparing to unpack .../79-mintstick_1.6.0_all.deb ...
Unpacking mintstick (1.6.0) over (1.5.8) ...
Preparing to unpack .../80-mintupdate_6.0.9_all.deb ...
Unpacking mintupdate (6.0.9) over (6.0.7) ...
Preparing to unpack .../81-modemmanager_1.20.0-1~ubuntu22.04.3_amd64.deb ...
Unpacking modemmanager (1.20.0-1~ubuntu22.04.3) over (1.20.0-1~ubuntu22.04.2) ..
Preparing to unpack .../82-openjdk-11-jre_11.0.22+7-0ubuntu2~22.04.1_amd64.deb .
Unpacking openjdk-11-jre:amd64 (11.0.22+7-0ubuntu2~22.04.1) over (11.0.21+9-0ubu
ntu1~22.04) ...
Preparing to unpack .../83-openjdk-11-jre-headless_11.0.22+7-0ubuntu2~22.04.1_am
d64.deb ...
Unpacking openjdk-11-jre-headless:amd64 (11.0.22+7-0ubuntu2~22.04.1) over (11.0.
21+9-0ubuntu1~22.04) ...
Preparing to unpack .../84-python3-cryptography_3.4.8-1ubuntu2.2_amd64.deb ...
Unpacking python3-cryptography (3.4.8-1ubuntu2.2) over (3.4.8-1ubuntu2.1) ...
Preparing to unpack .../85-python3-pil_9.0.1-1ubuntu0.2_amd64.deb ...
Unpacking python3-pil:amd64 (9.0.1-1ubuntu0.2) over (9.0.1-1ubuntu0.1) ...
Preparing to unpack .../86-python3-pycryptodome_3.11.0+dfsg1-3ubuntu0.1_amd64.de
b ...
Unpacking python3-pycryptodome (3.11.0+dfsg1-3ubuntu0.1) over (3.11.0+dfsg1-3bui
ld1) ...
Preparing to unpack .../87-transmission-common_3.00-2ubuntu2.1_all.deb ...
Unpacking transmission-common (3.00-2ubuntu2.1) over (3.00-2ubuntu2) ...
Preparing to unpack .../88-transmission-gtk_3.00-2ubuntu2.1_amd64.deb ...
Unpacking transmission-gtk (3.00-2ubuntu2.1) over (3.00-2ubuntu2) ...
Preparing to unpack .../89-unzip_6.0-26ubuntu3.2_amd64.deb ...
Unpacking unzip (6.0-26ubuntu3.2) over (6.0-26ubuntu3.1) ...
Preparing to unpack .../90-xserver-xephyr_2%3a21.1.4-2ubuntu1.7~22.04.8_amd64.de
b ...
Unpacking xserver-xephyr (2:21.1.4-2ubuntu1.7~22.04.8) over (2:21.1.4-2ubuntu1.7
~22.04.5) ...
Preparing to unpack .../91-xwayland_2%3a22.1.1-1ubuntu0.11_amd64.deb ...
Unpacking xwayland (2:22.1.1-1ubuntu0.11) over (2:22.1.1-1ubuntu0.9) ...
Preparing to unpack .../92-libnss-myhostname_249.11-0ubuntu3.12_amd64.deb ...
Unpacking libnss-myhostname:amd64 (249.11-0ubuntu3.12) over (249.11-0ubuntu3.11)
Setting up cups-ipp-utils (2.4.1op1-1ubuntu4.8) ...
Setting up libssh-gcrypt-4:amd64 (0.9.6-2ubuntu0.22.04.3) ...
Setting up libip4tc2:amd64 (1.8.7-1ubuntu5.2) ...
Setting up mesa-vulkan-drivers:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Setting up mesa-vdpau-drivers:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Setting up libnvpair3linux (2.1.5-1ubuntu6~22.04.3) ...
Setting up tcpdump (4.99.1-3ubuntu0.2) ...
Installing new version of config file /etc/apparmor.d/usr.bin.tcpdump ...
Setting up cups-server-common (2.4.1op1-1ubuntu4.8) ...
Setting up firefox (123.0.1+linuxmint1+virginia) ...
Setting up libgbm1:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Setting up alsa-ucm-conf (1.2.6.3-1ubuntu1.11) ...
Setting up linux-firmware (20220329.git681281e4-0ubuntu3.29) ...
update-initramfs: Generating /boot/initrd.img-5.15.0-91-generic
Setting up libip6tc2:amd64 (1.8.7-1ubuntu5.2) ...
Setting up libcpanel-json-xs-perl:amd64 (4.27-1ubuntu0.1) ...
Setting up python3-pycryptodome (3.11.0+dfsg1-3ubuntu0.1) ...
Setting up firmware-sof-signed (2.0-1ubuntu4.5) ...
Setting up cups-common (2.4.1op1-1ubuntu4.8) ...
Setting up unzip (6.0-26ubuntu3.2) ...
Setting up openjdk-11-jre-headless:amd64 (11.0.22+7-0ubuntu2~22.04.1) ...
Installing new version of config file /etc/java-11-openjdk/jfr/default.jfc ...
Installing new version of config file /etc/java-11-openjdk/jfr/profile.jfc ...
Setting up ltrace (0.7.3-6.1ubuntu6.22.04.1) ...
Setting up binutils-common:amd64 (2.38-4ubuntu2.6) ...
Setting up libjavascriptcoregtk-4.0-18:amd64 (2.42.5-0ubuntu0.22.04.2) ...
Setting up less (590-1ubuntu0.22.04.2) ...
Setting up linux-libc-dev:amd64 (5.15.0-101.111) ...
Setting up libctf-nobfd0:amd64 (2.38-4ubuntu2.6) ...
Setting up openjdk-11-jre:amd64 (11.0.22+7-0ubuntu2~22.04.1) ...
Setting up gir1.2-javascriptcoregtk-4.0:amd64 (2.42.5-0ubuntu0.22.04.2) ...
Setting up dnsmasq-base (2.90-0ubuntu0.22.04.1) ...
Setting up libgpgme11:amd64 (1.16.0-1.2ubuntu4.2) ...
Setting up xxd (2:8.2.3995-1ubuntu2.16) ...
Setting up cups-client (2.4.1op1-1ubuntu4.8) ...
Setting up libcupsimage2:amd64 (2.4.1op1-1ubuntu4.8) ...
Setting up libxatracker2:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Setting up libc6-dbg:amd64 (2.35-0ubuntu3.6) ...
Setting up dns-root-data (2023112702~ubuntu0.22.04.1) ...
Setting up tzdata (2024a-0ubuntu0.22.04) ...
Current default time zone: 'Europe/Istanbul'
Local time is now: Thu Mar 21 01:17:27 +03 2024.
Universal Time is now: Wed Mar 20 22:17:27 UTC 2024.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
Setting up linux-headers-5.15.0-101 (5.15.0-101.111) ...
Setting up mintstick (1.6.0) ...
Setting up python3-pil:amd64 (9.0.1-1ubuntu0.2) ...
Setting up mint-mirrors (1.2.6) ...
Setting up mint-upgrade-info (1.2.6) ...
Setting up libcscreensaver0:amd64 (6.0.3+virginia) ...
Setting up libjavascriptcoregtk-4.1-0:amd64 (2.42.5-0ubuntu0.22.04.2) ...
Setting up libuv1:amd64 (1.43.0-1ubuntu0.1) ...
Setting up vim-common (2:8.2.3995-1ubuntu2.16) ...
Setting up firefox-locale-en (123.0.1+linuxmint1+virginia) ...
Setting up python3-cryptography (3.4.8-1ubuntu2.2) ...
Setting up cups-daemon (2.4.1op1-1ubuntu4.8) ...
Setting up libnss-myhostname:amd64 (249.11-0ubuntu3.12) ...
Setting up mintreport (1.4.7) ...
Setting up cinnamon-session-common (6.0.4+virginia) ...
Setting up libxtables12:amd64 (1.8.7-1ubuntu5.2) ...
Setting up libglapi-mesa:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Setting up libdpkg-perl (1.21.1ubuntu2.3) ...
Setting up libkpathsea6:amd64 (2021.20210626.59705-1ubuntu0.2) ...
Setting up cinnamon-control-center-data (6.0.1+virginia) ...
Setting up libwebkit2gtk-4.0-37:amd64 (2.42.5-0ubuntu0.22.04.2) ...
Setting up libmm-glib0:amd64 (1.20.0-1~ubuntu22.04.3) ...
Setting up libcinnamon-control-center1:amd64 (6.0.1+virginia) ...
Setting up modemmanager (1.20.0-1~ubuntu22.04.3) ...
Setting up xserver-common (2:21.1.4-2ubuntu1.7~22.04.8) ...
Setting up mesa-va-drivers:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Setting up libaccountsservice0:amd64 (22.07.5-2ubuntu1.5) ...
Setting up xwayland (2:22.1.1-1ubuntu0.11) ...
Setting up libbinutils:amd64 (2.38-4ubuntu2.6) ...
Setting up libuutil3linux (2.1.5-1ubuntu6~22.04.3) ...
Setting up libde265-0:amd64 (1.0.8-1ubuntu0.3) ...
Setting up transmission-common (3.00-2ubuntu2.1) ...
Setting up xserver-xorg-legacy (2:21.1.4-2ubuntu1.7~22.04.8) ...
Setting up linux-headers-5.15.0-101-generic (5.15.0-101.111) ...
/etc/kernel/header_postinst.d/dkms:
* dkms: running auto installation service for kernel 5.15.0-101-generic
...done.
Setting up accountsservice (22.07.5-2ubuntu1.5) ...
Setting up libctf0:amd64 (2.38-4ubuntu2.6) ...
Setting up cups-ppdc (2.4.1op1-1ubuntu4.8) ...
Setting up libwebkit2gtk-4.1-0:amd64 (2.42.5-0ubuntu0.22.04.2) ...
Setting up cups-core-drivers (2.4.1op1-1ubuntu4.8) ...
Setting up gir1.2-webkit2-4.0:amd64 (2.42.5-0ubuntu0.22.04.2) ...
Setting up cinnamon-screensaver (6.0.3+virginia) ...
Setting up libgpgmepp6:amd64 (1.16.0-1.2ubuntu4.2) ...
Setting up cups (2.4.1op1-1ubuntu4.8) ...
Updating PPD files for cups ...
Updating PPD files for cups-filters ...
Updating PPD files for foomatic-db-compressed-ppds ...
Updating PPD files for openprinting-ppds ...
Updating PPD files for brlaser ...
Updating PPD files for c2esp ...
Updating PPD files for foo2zjs-common ...
Updating PPD files for gutenprint ...
Updating PPD files for hpcups ...
Updating PPD files for m2300w ...
Updating PPD files for postscript-hp ...
Updating PPD files for ptouch ...
Updating PPD files for pxljr ...
Updating PPD files for sag-gdi ...
Updating PPD files for splix ...
Setting up bind9-libs:amd64 (1:9.18.18-0ubuntu0.22.04.2) ...
Setting up cups-bsd (2.4.1op1-1ubuntu4.8) ...
Setting up iptables (1.8.7-1ubuntu5.2) ...
Setting up cinnamon-session (6.0.4+virginia) ...
Setting up libgl1-mesa-dri:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Setting up xserver-xorg-core (2:21.1.4-2ubuntu1.7~22.04.8) ...
Setting up linux-headers-generic (5.15.0.101.98) ...
Setting up vim-tiny (2:8.2.3995-1ubuntu2.16) ...
Setting up gir1.2-accountsservice-1.0:amd64 (22.07.5-2ubuntu1.5) ...
Setting up mintupdate (6.0.9) ...
The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
Alias= settings in the [Install] section, and DefaultInstance= for template
units). This means they are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
• A unit may be statically enabled by being symlinked from another unit's
.wants/ or .requires/ directory.
• A unit's purpose may be to act as a helper for some other unit which has
a requirement dependency on it.
• A unit may be started when needed via activation (socket, path, timer,
D-Bus, udev, scripted systemctl call, ...).
• In case of template units, the unit is meant to be enabled with some
instance name specified.
Setting up libzfs4linux (2.1.5-1ubuntu6~22.04.3) ...
Setting up gir1.2-javascriptcoregtk-4.1:amd64 (2.42.5-0ubuntu0.22.04.2) ...
Setting up libegl-mesa0:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Setting up transmission-gtk (3.00-2ubuntu2.1) ...
Setting up xserver-xephyr (2:21.1.4-2ubuntu1.7~22.04.8) ...
Setting up bind9-host (1:9.18.18-0ubuntu0.22.04.2) ...
Setting up libzpool5linux (2.1.5-1ubuntu6~22.04.3) ...
Setting up binutils-x86-64-linux-gnu (2.38-4ubuntu2.6) ...
Setting up libglx-mesa0:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Setting up gir1.2-webkit2-4.1:amd64 (2.42.5-0ubuntu0.22.04.2) ...
Setting up binutils (2.38-4ubuntu2.6) ...
Setting up dpkg-dev (1.21.1ubuntu2.3) ...
Setting up zfsutils-linux (2.1.5-1ubuntu6~22.04.3) ...
zfs-import-scan.service is a disabled or a static unit, not starting it.
Setting up zfs-initramfs (2.1.5-1ubuntu6~22.04.3) ...
Setting up bind9-dnsutils (1:9.18.18-0ubuntu0.22.04.2) ...
Setting up zfs-zed (2.1.5-1ubuntu6~22.04.3) ...
Setting up linux-image-5.15.0-101-generic (5.15.0-101.111) ...
I: /boot/vmlinuz.old is now a symlink to vmlinuz-5.15.0-91-generic
I: /boot/vmlinuz is now a symlink to vmlinuz-5.15.0-101-generic
I: /boot/initrd.img is now a symlink to initrd.img-5.15.0-101-generic
Setting up linux-modules-extra-5.15.0-101-generic (5.15.0-101.111) ...
Setting up linux-modules-5.15.0-101-generic (5.15.0-101.111) ...
Setting up linux-image-generic (5.15.0.101.98) ...
Setting up linux-generic (5.15.0.101.98) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu3) ...
Processing triggers for libglib2.0-0:amd64 (2.72.4-0ubuntu2.2) ...
Processing triggers for libc-bin (2.35-0ubuntu3.6) ...
Setting up cinnamon-control-center (6.0.1+virginia) ...
Processing triggers for dbus (1.12.20-2ubuntu4.1) ...
Processing triggers for mintsystem (8.5.8) ...
Processing triggers for install-info (6.8-4build1) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
Processing triggers for desktop-file-utils (0.26+mint3+victoria) ...
Processing triggers for initramfs-tools (0.140ubuntu13.4) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for doc-base (0.11.1) ...
Processing 3 changed doc-base files...
Setting up cinnamon-control-center-dbg (6.0.1+virginia) ...
Processing triggers for linux-image-5.15.0-101-generic (5.15.0-101.111) ...
/etc/kernel/postinst.d/dkms:
...done.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.15.0-101-generic
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/50_linuxmint.cfg'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.15.0-101-generic
Found initrd image: /boot/initrd.img-5.15.0-101-generic
Found linux image: /boot/vmlinuz-5.15.0-91-generic
Found initrd image: /boot/initrd.img-5.15.0-91-generic
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot
entries.
Adding boot menu entry for UEFI Firmware Settings ...
done
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra$ sudo ./apply_binaries.sh
Using rootfs directory of: /home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/rootfs
Installing extlinux.conf into /boot/extlinux in target rootfs
/home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
Root file system directory is /home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/rootfs
Copying public debian packages to rootfs
Skipping installation of nvidia-l4t-dgpu-apt-source_35.4.1-20230801124926_arm64.deb ....
Skipping installation of nvidia-l4t-dgpu-config_35.4.1-20230801124926_arm64.deb ....
Skipping installation of nvidia-l4t-factory-service_35.4.1-20230801124926_arm64.deb ....
Start L4T BSP package installation
QEMU binary is not available, looking for QEMU from host system
ERROR qemu not found! To install - please run: "sudo apt-get install qemu-user-static"
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra$ sudo apt-get install qemu-user-static
binfmt-support
binfmt-support qemu-user-static
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 13,0 MB of archives.
After this operation, 130 MB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu jammy/main amd64 binfmt-support amd64 2.2.1-2 [55,8 kB]
Get:2 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 qemu-user-static amd64 1:6.2+dfsg-2ubuntu6.17 [13,0 MB]
Fetched 13,0 MB in 4s (3.395 kB/s)
Selecting previously unselected package binfmt-support.
(Reading database ... 566968 files and directories currently installed.)
Preparing to unpack .../binfmt-support_2.2.1-2_amd64.deb ...
Unpacking binfmt-support (2.2.1-2) ...
Selecting previously unselected package qemu-user-static.
Preparing to unpack .../qemu-user-static_1%3a6.2+dfsg-2ubuntu6.17_amd64.deb ...
Unpacking qemu-user-static (1:6.2+dfsg-2ubuntu6.17) ...
Setting up qemu-user-static (1:6.2+dfsg-2ubuntu6.17) ...
Setting up binfmt-support (2.2.1-2) ...
update-binfmts: warning: python3.10 already enabled in kernel.
Created symlink /etc/systemd/system/multi-user.target.wants/binfmt-support.service → /lib/systemd/system/binfmt-support.service.
Found /usr/bin/qemu-aarch64-static
Installing QEMU binary in rootfs
/home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/rootfs /home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra
Installing BSP Debian packages in /home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/rootfs
Selecting previously unselected package nvidia-l4t-core.
(Reading database ... 123435 files and directories currently installed.)
Preparing to unpack .../nvidia-l4t-core_35.4.1-20230801124926_arm64.deb ...
Pre-installing... skip compatibility checking.
Unpacking nvidia-l4t-core (35.4.1-20230801124926) ...
Setting up nvidia-l4t-core (35.4.1-20230801124926) ...
Selecting previously unselected package jetson-gpio-common.
(Reading database ... 123493 files and directories currently installed.)
Preparing to unpack .../jetson-gpio-common_2.1.1ubuntu1_arm64.deb ...
Unpacking jetson-gpio-common (2.1.1ubuntu1) ...
Selecting previously unselected package python3-jetson-gpio.
Preparing to unpack .../python3-jetson-gpio_2.1.1ubuntu1_arm64.deb ...
Unpacking python3-jetson-gpio (2.1.1ubuntu1) ...
Selecting previously unselected package python-jetson-gpio.
Preparing to unpack .../python-jetson-gpio_2.1.1ubuntu1_arm64.deb ...
Unpacking python-jetson-gpio (2.1.1ubuntu1) ...
Selecting previously unselected package nvidia-l4t-3d-core.
Preparing to unpack .../nvidia-l4t-3d-core_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-3d-core (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-apt-source.
Preparing to unpack .../nvidia-l4t-apt-source_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-apt-source (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-camera.
Preparing to unpack .../nvidia-l4t-camera_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-camera (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-configs.
Preparing to unpack .../nvidia-l4t-configs_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-configs (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-cuda.
Preparing to unpack .../nvidia-l4t-cuda_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-cuda (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-firmware.
Preparing to unpack .../nvidia-l4t-firmware_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-firmware (35.4.1-20230801124926) ...
Replacing files in old package linux-firmware (1.187.39) ...
Selecting previously unselected package nvidia-l4t-gbm.
Preparing to unpack .../nvidia-l4t-gbm_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-gbm (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-graphics-demos.
Preparing to unpack .../nvidia-l4t-graphics-demos_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-graphics-demos (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-gstreamer.
Preparing to unpack .../nvidia-l4t-gstreamer_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-gstreamer (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-init.
Preparing to unpack .../nvidia-l4t-init_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-init (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-initrd.
Preparing to unpack .../nvidia-l4t-initrd_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-initrd (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-jetson-io.
Preparing to unpack .../nvidia-l4t-jetson-io_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-jetson-io (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-jetsonpower-gui-tools.
Preparing to unpack .../nvidia-l4t-jetsonpower-gui-tools_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-jetsonpower-gui-tools (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-libvulkan.
Preparing to unpack .../nvidia-l4t-libvulkan_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-libvulkan (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-multimedia.
Preparing to unpack .../nvidia-l4t-multimedia_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-multimedia (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-multimedia-utils.
Preparing to unpack .../nvidia-l4t-multimedia-utils_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-multimedia-utils (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-nvfancontrol.
Preparing to unpack .../nvidia-l4t-nvfancontrol_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-nvfancontrol (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-nvpmodel.
Preparing to unpack .../nvidia-l4t-nvpmodel_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-nvpmodel (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-nvpmodel-gui-tools.
Preparing to unpack .../nvidia-l4t-nvpmodel-gui-tools_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-nvpmodel-gui-tools (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-nvsci.
Preparing to unpack .../nvidia-l4t-nvsci_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-nvsci (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-oem-config.
Preparing to unpack .../nvidia-l4t-oem-config_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-oem-config (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-openwfd.
Preparing to unpack .../nvidia-l4t-openwfd_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-openwfd (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-optee.
Preparing to unpack .../nvidia-l4t-optee_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-optee (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-pva.
Preparing to unpack .../nvidia-l4t-pva_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-pva (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-tools.
Preparing to unpack .../nvidia-l4t-tools_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-tools (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-vulkan-sc.
Preparing to unpack .../nvidia-l4t-vulkan-sc_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-vulkan-sc (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-vulkan-sc-dev.
Preparing to unpack .../nvidia-l4t-vulkan-sc-dev_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-vulkan-sc-dev (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-vulkan-sc-samples.
Preparing to unpack .../nvidia-l4t-vulkan-sc-samples_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-vulkan-sc-samples (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-vulkan-sc-sdk.
Preparing to unpack .../nvidia-l4t-vulkan-sc-sdk_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-vulkan-sc-sdk (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-wayland.
Preparing to unpack .../nvidia-l4t-wayland_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-wayland (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-weston.
Preparing to unpack .../nvidia-l4t-weston_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-weston (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-x11.
Preparing to unpack .../nvidia-l4t-x11_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-x11 (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-xusb-firmware.
Preparing to unpack .../nvidia-l4t-xusb-firmware_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-xusb-firmware (35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-display-kernel.
Preparing to unpack .../nvidia-l4t-display-kernel_5.10.120-tegra-35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-display-kernel (5.10.120-tegra-35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-kernel.
Preparing to unpack .../nvidia-l4t-kernel_5.10.120-tegra-35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-kernel (5.10.120-tegra-35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-kernel-dtbs.
Preparing to unpack .../nvidia-l4t-kernel-dtbs_5.10.120-tegra-35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-kernel-dtbs (5.10.120-tegra-35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-kernel-headers.
Preparing to unpack .../nvidia-l4t-kernel-headers_5.10.120-tegra-35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-kernel-headers (5.10.120-tegra-35.4.1-20230801124926) ...
Selecting previously unselected package nvidia-l4t-bootloader.
Preparing to unpack .../nvidia-l4t-bootloader_35.4.1-20230801124926_arm64.deb ...
Unpacking nvidia-l4t-bootloader (35.4.1-20230801124926) ...
Setting up jetson-gpio-common (2.1.1ubuntu1) ...
Setting up python3-jetson-gpio (2.1.1ubuntu1) ...
Setting up python-jetson-gpio (2.1.1ubuntu1) ...
Setting up nvidia-l4t-apt-source (35.4.1-20230801124926) ...
Pre-installing... skip changing source list.
Setting up nvidia-l4t-configs (35.4.1-20230801124926) ...
Setting up nvidia-l4t-cuda (35.4.1-20230801124926) ...
Setting up nvidia-l4t-firmware (35.4.1-20230801124926) ...
Setting up nvidia-l4t-init (35.4.1-20230801124926) ...
Setting up nvidia-l4t-jetsonpower-gui-tools (35.4.1-20230801124926) ...
Setting up nvidia-l4t-libvulkan (35.4.1-20230801124926) ...
Setting up nvidia-l4t-multimedia-utils (35.4.1-20230801124926) ...
Setting up nvidia-l4t-nvfancontrol (35.4.1-20230801124926) ...
Setting up nvidia-l4t-nvpmodel (35.4.1-20230801124926) ...
Setting up nvidia-l4t-nvpmodel-gui-tools (35.4.1-20230801124926) ...
Setting up nvidia-l4t-nvsci (35.4.1-20230801124926) ...
Setting up nvidia-l4t-oem-config (35.4.1-20230801124926) ...
Setting up nvidia-l4t-openwfd (35.4.1-20230801124926) ...
Setting up nvidia-l4t-optee (35.4.1-20230801124926) ...
Setting up nvidia-l4t-pva (35.4.1-20230801124926) ...
Setting up nvidia-l4t-tools (35.4.1-20230801124926) ...
Setting up nvidia-l4t-vulkan-sc (35.4.1-20230801124926) ...
Setting up nvidia-l4t-vulkan-sc-dev (35.4.1-20230801124926) ...
Setting up nvidia-l4t-vulkan-sc-sdk (35.4.1-20230801124926) ...
Setting up nvidia-l4t-wayland (35.4.1-20230801124926) ...
Setting up nvidia-l4t-x11 (35.4.1-20230801124926) ...
Setting up nvidia-l4t-xusb-firmware (35.4.1-20230801124926) ...
Setting up nvidia-l4t-kernel (5.10.120-tegra-35.4.1-20230801124926) ...
Using the existing boot entry 'primary'
Pre-installing kernel package, skip flashing
Setting up nvidia-l4t-kernel-dtbs (5.10.120-tegra-35.4.1-20230801124926) ...
Pre-installing kernel-dtbs package, skip flashing
Setting up nvidia-l4t-kernel-headers (5.10.120-tegra-35.4.1-20230801124926) ...
Setting up nvidia-l4t-bootloader (35.4.1-20230801124926) ...
Pre-installing bootloader package, skip flashing
Setting up nvidia-l4t-3d-core (35.4.1-20230801124926) ...
Setting up nvidia-l4t-gbm (35.4.1-20230801124926) ...
Setting up nvidia-l4t-initrd (35.4.1-20230801124926) ...
Pre-installing initrd package, skip flashing
Setting up nvidia-l4t-jetson-io (35.4.1-20230801124926) ...
Setting up nvidia-l4t-multimedia (35.4.1-20230801124926) ...
Setting up nvidia-l4t-vulkan-sc-samples (35.4.1-20230801124926) ...
Setting up nvidia-l4t-weston (35.4.1-20230801124926) ...
Setting up nvidia-l4t-display-kernel (5.10.120-tegra-35.4.1-20230801124926) ...
Setting up nvidia-l4t-camera (35.4.1-20230801124926) ...
Setting up nvidia-l4t-graphics-demos (35.4.1-20230801124926) ...
Setting up nvidia-l4t-gstreamer (35.4.1-20230801124926) ...
Processing triggers for nvidia-l4t-kernel (5.10.120-tegra-35.4.1-20230801124926) ...
Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
Removing QEMU binary from rootfs
Removing stashed Debian packages from rootfs
L4T BSP package installation completed!
Disabling NetworkManager-wait-online.service
Disable the ondemand service by changing the runlevels to 'K'
Success!
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/t186ref/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit nvme0n1p1
/home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -p -c ./bootloader/t186ref/cfg/flash_t234_qspi.xml -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit nvme0n1p1
ERROR sshpass not found! To install - please run: "sudo apt-get install sshpass"
Cleaning up...
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra$ sudo apt-get install sshpass
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following NEW packages will be installed:
sshpass
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 11,7 kB of archives.
After this operation, 35,8 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu jammy/universe amd64 sshpass amd64 1.09-1 [11,7 kB]
Fetched 11,7 kB in 0s (44,9 kB/s)
Selecting previously unselected package sshpass.
(Reading database ... 567116 files and directories currently installed.)
Preparing to unpack .../sshpass_1.09-1_amd64.deb ...
Unpacking sshpass (1.09-1) ...
Setting up sshpass (1.09-1) ...
Processing triggers for man-db (2.10.2-1) ...
ERROR abootimg not found! To install - please run: "sudo apt-get install abootimg"
Cleaning up...
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra$ sudo apt-get install abootimg
abootimg
Need to get 14,2 kB of archives.
After this operation, 43,0 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu jammy/universe amd64 abootimg amd64 0.6-1build1 [14,2 kB]
Fetched 14,2 kB in 0s (53,4 kB/s)
Selecting previously unselected package abootimg.
(Reading database ... 567121 files and directories currently installed.)
Preparing to unpack .../abootimg_0.6-1build1_amd64.deb ...
Unpacking abootimg (0.6-1build1) ...
Setting up abootimg (0.6-1build1) ...
ERROR nfs-kernel-server not found! To install - please run: "sudo apt-get install nfs-kernel-server"
Cleaning up...
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra$ sudo apt-get install nfs-kernel-server
The following additional packages will be installed:
libevent-core-2.1-7 libnfsidmap1 nfs-common rpcbind
Suggested packages:
open-iscsi watchdog
libevent-core-2.1-7 libnfsidmap1 nfs-common nfs-kernel-server rpcbind
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 522 kB/565 kB of archives.
After this operation, 2.073 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu jammy/main amd64 libevent-core-2.1-7 amd64 2.1.12-stable-1build3 [93,9 kB]
Get:2 http://archive.ubuntu.com/ubuntu jammy/main amd64 rpcbind amd64 1.2.6-2build1 [46,6 kB]
Get:3 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 nfs-common amd64 1:2.6.1-1ubuntu1.2 [241 kB]
Get:4 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 nfs-kernel-server amd64 1:2.6.1-1ubuntu1.2 [140 kB]
Fetched 522 kB in 1s (389 kB/s)
Selecting previously unselected package libevent-core-2.1-7:amd64.
(Reading database ... 567129 files and directories currently installed.)
Preparing to unpack .../libevent-core-2.1-7_2.1.12-stable-1build3_amd64.deb ...
Unpacking libevent-core-2.1-7:amd64 (2.1.12-stable-1build3) ...
Selecting previously unselected package libnfsidmap1:amd64.
Preparing to unpack .../libnfsidmap1_1%3a2.6.1-1ubuntu1.2_amd64.deb ...
Unpacking libnfsidmap1:amd64 (1:2.6.1-1ubuntu1.2) ...
Selecting previously unselected package rpcbind.
Preparing to unpack .../rpcbind_1.2.6-2build1_amd64.deb ...
Unpacking rpcbind (1.2.6-2build1) ...
Selecting previously unselected package nfs-common.
Preparing to unpack .../nfs-common_1%3a2.6.1-1ubuntu1.2_amd64.deb ...
Unpacking nfs-common (1:2.6.1-1ubuntu1.2) ...
Selecting previously unselected package nfs-kernel-server.
Preparing to unpack .../nfs-kernel-server_1%3a2.6.1-1ubuntu1.2_amd64.deb ...
Unpacking nfs-kernel-server (1:2.6.1-1ubuntu1.2) ...
Setting up libnfsidmap1:amd64 (1:2.6.1-1ubuntu1.2) ...
Setting up rpcbind (1.2.6-2build1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/rpcbind.service → /lib/systemd/system/rpcbind.service.
Created symlink /etc/systemd/system/sockets.target.wants/rpcbind.socket → /lib/systemd/system/rpcbind.socket.
Setting up libevent-core-2.1-7:amd64 (2.1.12-stable-1build3) ...
Setting up nfs-common (1:2.6.1-1ubuntu1.2) ...
Creating config file /etc/idmapd.conf with new version
Creating config file /etc/nfs.conf with new version
Adding system user `statd' (UID 130) ...
Adding new user `statd' (UID 130) with group `nogroup' ...
Not creating home directory `/var/lib/nfs'.
Created symlink /etc/systemd/system/multi-user.target.wants/nfs-client.target → /lib/systemd/system/nfs-client.target.
Created symlink /etc/systemd/system/remote-fs.target.wants/nfs-client.target → /lib/systemd/system/nfs-client.target.
auth-rpcgss-module.service is a disabled or a static unit, not starting it.
nfs-idmapd.service is a disabled or a static unit, not starting it.
nfs-utils.service is a disabled or a static unit, not starting it.
proc-fs-nfsd.mount is a disabled or a static unit, not starting it.
rpc-gssd.service is a disabled or a static unit, not starting it.
rpc-statd-notify.service is a disabled or a static unit, not starting it.
rpc-statd.service is a disabled or a static unit, not starting it.
rpc-svcgssd.service is a disabled or a static unit, not starting it.
rpc_pipefs.target is a disabled or a static unit, not starting it.
var-lib-nfs-rpc_pipefs.mount is a disabled or a static unit, not starting it.
Setting up nfs-kernel-server (1:2.6.1-1ubuntu1.2) ...
Created symlink /etc/systemd/system/nfs-client.target.wants/nfs-blkmap.service → /lib/systemd/system/nfs-blkmap.service.
Created symlink /etc/systemd/system/multi-user.target.wants/nfs-server.service → /lib/systemd/system/nfs-server.service.
nfs-mountd.service is a disabled or a static unit, not starting it.
nfsdcld.service is a disabled or a static unit, not starting it.
Creating config file /etc/exports with new version
Creating config file /etc/default/nfs-kernel-server with new version
* Step 1: Generate flash packages *
ERROR xmllint not found! To install - please run: "sudo apt-get install libxml2-utils"
Cleaning up...
fidenet@fidenet-OptiPlex-3070:~/Desktop/JetsonOrin/Linux_for_Tegra$ sudo apt-get install libxml2-utils
libxml2-utils
Need to get 40,2 kB of archives.
After this operation, 207 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libxml2-utils amd64 2.9.13+dfsg-1ubuntu0.4 [40,2 kB]
Fetched 40,2 kB in 1s (60,5 kB/s)
Selecting previously unselected package libxml2-utils.
(Reading database ... 567286 files and directories currently installed.)
Preparing to unpack .../libxml2-utils_2.9.13+dfsg-1ubuntu0.4_amd64.deb ...
Unpacking libxml2-utils (2.9.13+dfsg-1ubuntu0.4) ...
Setting up libxml2-utils (2.9.13+dfsg-1ubuntu0.4) ...
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY="" /home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/flash.sh --no-flash --sign -c ./bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit nvme0n1p1
# L4T BSP Information:
# R35 , REVISION: 4.1
# User release: 0.0
copying emc_fuse_dev_params(/home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0370 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0374 ] File rcm_state open failed
[ 0.0376 ] ERROR: failed to read rcm_state
[ 0.0376 ]
[ 0.0457 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0459 ] Assuming zero filled SBK key
[ 0.0379 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0637 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0742 ] Parsing partition layout
[ 0.0746 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0766 ] Kernel DTB used: None
[ 0.0766 ] WARNING: dce base dtb is not provided
[ 0.0766 ] Parsing partition layout
[ 0.0770 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0775 ] Creating list of images to be signed
[ 0.0780 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0783 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0807 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0811 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0862 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0866 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0924 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0927 ] adding BCH for mb2_t234_aligned.bin
[ 0.0965 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.1104 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.1107 ] adding BCH for mb2_t234_aligned.bin
[ 0.1253 ] Filling MB1 storage info
[ 0.1253 ] Parsing dev params for multi chains
[ 0.1317 ] Generating br-bct
[ 0.1322 ] Updating dev and MSS params in BR BCT
[ 0.1322 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1350 ] Updating bl info
[ 0.1354 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.1357 ] WARNING: boot chain is not completed. set to 0
[ 0.1363 ] Generating signatures
[ 0.1444 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1445 ] Assuming zero filled SBK key
[ 0.1550 ] Warning: pub_key.key is not found
[ 0.1471 ] Parsing dev params for multi chains
[ 0.1471 ] Generating br-bct
[ 0.1474 ] Updating dev and MSS params in BR BCT
[ 0.1474 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1479 ] Updating bl info
[ 0.1483 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1485 ] WARNING: boot chain is not completed. set to 0
[ 0.1496 ] Get Signed section of bct
[ 0.1499 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1505 ] Signing BCT
[ 0.1586 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1587 ] Assuming zero filled SBK key
[ 0.1604 ] Sha saved in br_bct_BR.sha
[ 0.1606 ] Warning: pub_key.key is not found
[ 0.1525 ] Updating BCT with signature
[ 0.1529 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1532 ] Offset :4608 Len :3584
[ 0.1535 ] Generating SHA2 Hash
[ 0.1616 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1617 ] Assuming zero filled SBK key
[ 0.1632 ] Sha saved in br_bct_BR.sha
[ 0.1553 ] Updating BCT with SHA2 Hash
[ 0.1556 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1559 ] Offset :4608 Len :3584
[ 0.1562 ] Offset :68 Len :8124
[ 0.1564 ] Generating coldboot mb1-bct
[ 0.1568 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1572 ] MB1-BCT version: 0.10
[ 0.1575 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1580 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1583 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1586 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1588 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1591 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1594 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1595 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1595 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1595 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1595 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1595 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1595 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1595 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1595 ]
[ 0.1595 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1595 ] Added Platform Config 9 data with size :- 100
[ 0.1595 ]
[ 0.1595 ] Updating mb1-bct with firmware information
[ 0.1600 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1612 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1621 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1625 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1714 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1715 ] Assuming zero filled SBK key
[ 0.1729 ] Warning: pub_key.key is not found
[ 0.1653 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1663 ] Generating recovery mb1-bct
[ 0.1668 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1671 ] MB1-BCT version: 0.10
[ 0.1673 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1677 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1680 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1682 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1684 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1687 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1690 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1691 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1691 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1691 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1691 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1691 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1691 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1691 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1691 ]
[ 0.1691 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1692 ] Added Platform Config 9 data with size :- 100
[ 0.1692 ]
[ 0.1692 ] Updating mb1-bct with firmware information
[ 0.1696 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1708 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1717 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1720 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1809 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1810 ] Assuming zero filled SBK key
[ 0.1823 ] Warning: pub_key.key is not found
[ 0.1747 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1757 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1757 ] Copying signatures
[ 0.1762 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1817 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1819 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1819 ] Boot Rom communication
[ 0.1824 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1828 ] BR_CID: 0x80012344705DD81B4400000004008280
[ 0.3789 ] Sending bct_br
[ 0.5942 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
Error: /home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /home/fidenet/Desktop/JetsonOrin/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up...
