VS Code Plarformio ve CP2102 USB Dönüştürücü ile Attiny13a Programlama
Set Fuses yaptın mı?
Şimdi yaptım. Fail Veriyor
TARGET CONFIGURATION:
Target = attiny13a
Clock speed = 9600000L
Oscillator = internal
BOD level = 2.7v
Save EEPROM = yes
Bootloader type = no_bootloader
Selected fuses: [lfuse = 0x3a, hfuse = 0xfb]
Setting fuses
avrdude error: cannot open port \\.\COM[5]: Sistem belirtilen dosyay\xfd bulam\xfdyor.
avrdude error: unable to open programmer stk500v1 on port COM[5]
avrdude done.  Thank you.
*** [fuses] Error 1
======================================================================================================================================= [FAILED] Took 0.81 seconds =======================================================================================================================================
 *  The terminal process "C:\Users\gokrt\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'fuses', '--environment', 'attiny13a'" terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
COM[5] yerine COM5 denedin mi? COM5'te hala bağlı mı yoksa tak çıkar yapınca değişti mi?
COM5 yapınca oldu. Artık 1sn de 1 blink yapıyor.
Yalnız bu ayarları filan akılda tutmak zor. Arduino IDE belki işlevsel değil ama kolay.
Target = attiny13a
BOD level = 2.7v
Save EEPROM = yes
Setting fuses
avrdude: AVR device initialized and ready to accept instructions
avrdude: device signature = 0x1e9007 (probably t13a)
avrdude: erasing chip
avrdude: processing -U lock:w:0xff:m
avrdude: reading input file 0xff for lock
         with 1 byte in 1 section within [0, 0]
avrdude: writing 1 byte lock ...
avrdude: 1 byte of lock written
avrdude: verifying lock memory against 0xff
avrdude: 1 byte of lock verified
avrdude: processing -U hfuse:w:0xfb:m
avrdude: reading input file 0xfb for hfuse
avrdude: writing 1 byte hfuse ...
avrdude: 1 byte of hfuse written
avrdude: verifying hfuse memory against 0xfb
avrdude: 1 byte of hfuse verified
avrdude: processing -U lfuse:w:0x3a:m
avrdude: reading input file 0x3a for lfuse
avrdude: writing 1 byte lfuse ...
avrdude: 1 byte of lfuse written
avrdude: verifying lfuse memory against 0x3a
avrdude: 1 byte of lfuse verified
======================================================================================================================================= [SUCCESS] Took 1.94 seconds =======================================================================================================================================
Şu an akılda tutacak bir şey var mı? platformio.ini'yi hazırladık, bundan sonrası copy/paste.
Yeri geliyor format atıyoruz, yeri geliyor silip yüklüyoruz. Üstünden zaman geçince unuturum ben. Gerçi dosyayı açınca aynı ayarlar gelir de yeni sketch açınca afallayabilirim. :)
İşte copy/paste orada güzel :)
Bu arada usbasp alırsan tek satır configle bütün bunları çalıştırabiliyoruz sanıyorum.
usbasp alayım bir tane.
Bu arada her kod yüklediğimizde set fuses yapmamız gerekiyor mu? yoksa bir kez mi yapılıyor acaba?
"usbasp" her zaman iyidir.
Bir kere sigorta ayarlarını yapmanız yeterli. Ancak
yükleme işlemi yapılırken sigorta ayarlarını da
yüklemek daha uygun. Bazı zamanlarda kod
koruma yapılabilir. Bazı durumlarda BOR
gerilimi ile oynamak gerekir.
Bu durumda "Avrdude" ile önce mcuyu silmeniz
uygun olacaktır. Dolayısıyla her durumda sigorta
ayarlarını yeniden yapmak en iyisi olur.
Egemen
