Yeni kod bloğu
 *  Connection Manager
 *  Copyright (C) 2007-2013  Intel Corporation. All rights reserved.
 *  This program is free software; you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License version 2 as
 *  published by the Free Software Foundation.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program; if not, write to the Free Software
 *  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#ifdef HAVE_CONFIG_H
#include <config.h>
#endif
#include <errno.h>
#include <string.h>
#include <gdbus.h>
#include "connman.h"
DBusMessage *__connman_error_failed(DBusMessage *msg, int errnum)
    const char *str = strerror(errnum);
    switch (errnum) {
    case ESRCH:
        return __connman_error_not_registered(msg);
    case ENXIO:
        return __connman_error_not_found(msg);
    case EACCES:
        return __connman_error_permission_denied(msg);
    case EEXIST:
        return __connman_error_already_exists(msg);
    case EINVAL:
        return __connman_error_invalid_arguments(msg);
    case ENOSYS:
        return __connman_error_not_implemented(msg);
    case ENOLINK:
        return __connman_error_no_carrier(msg);
    case ENOTUNIQ:
        return __connman_error_not_unique(msg);
    case EOPNOTSUPP:
        return __connman_error_not_supported(msg);
    case ECONNABORTED:
        return __connman_error_operation_aborted(msg);
    case EISCONN:
        return __connman_error_already_connected(msg);
    case ENOTCONN:
    case ECONNREFUSED:
        return __connman_error_not_connected(msg);
    case ETIMEDOUT:
        return __connman_error_operation_timeout(msg);
    case EALREADY:
    case EINPROGRESS:
        return __connman_error_in_progress(msg);
    case ENOKEY:
        return __connman_error_passphrase_required(msg);
    return g_dbus_create_error(msg, CONNMAN_ERROR_INTERFACE
                    ".Failed", "%s", str);
Ahanda bir kod daha
struct connman_inotify {
    unsigned int refcount;
    GIOChannel *channel;
    uint watch;
    int wd;
    GSList *list;
teteni
