Dede
- Katılım
- 24 Mayıs 2024
- Mesajlar
- 1,355
32-Channel Serial-to-Parallel Converter with High-Voltage Push-Pull Outputs
ve maalesef ki PLCC kılıfında...
Features
• 80V Maximum Output Voltage
• Low-Power Level Shifting
• 8 MHz Shift Register Speed
• Latched Data Outputs
• 5V CMOS-Compatible Inputs
• Forward and Reverse Shifting Options
• Diode to VPP allows Efficient Power Recovery
Applications
• Piezoelectric Driver
• Inkjet Printer Driver
• Display Driver
• Microelectromechanical Systems Applications
HV9808 Datasheet
Features
Applications
• Display Driver
HV9808 Datasheet
