WD mycloud NAS arızası.
Dede
24 Mayıs 2024
Biryerden elime 2TB WD mycloud tek diskli NAS aleti geçti.
Kaba bir kitaplık gibi bişey.
Uğraşmaya değermi bilemedim.
HDD ölmüş.
SSH Raporu şöyle:
=== START OF INFORMATION SECTION ===
Device Model:     WDC WD20EFRX-68EUZN0
Serial Number:    WD-WCC4M5FAES9H
Firmware Version: 82.00A82
User Capacity:    2,000,398,934,016 bytes
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   9
ATA Standard is:  Exact ATA specification draft version not indicated
Local Time is:    Mon Dec  1 12:46:06 2025 PST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                 (26580) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 255) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   188   174   021    Pre-fail  Always       -       3566
  4 Start_Stop_Count        0x0032   084   084   000    Old_age   Always       -       16350
  5 Reallocated_Sector_Ct   0x0033   133   133   140    Pre-fail  Always   FAILING_NOW 1971
  7 Seek_Error_Rate         0x002e   200   198   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       75754
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       62
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       52
193 Load_Cycle_Count        0x0032   194   194   000    Old_age   Always       -       19653
194 Temperature_Celsius     0x0022   106   092   000    Old_age   Always       -       41
196 Reallocated_Event_Count 0x0032   161   161   000    Old_age   Always       -       39
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
Warning: ATA error count 50756 inconsistent with error log pointer 3
ATA Error Count: 50756 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        SC = Sector Count Register [HEX]
        SN = Sector Number Register [HEX]
        CL = Cylinder Low Register [HEX]
        CH = Cylinder High Register [HEX]
        DH = Device/Head Register [HEX]
        DC = Device Command Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 50756 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  04 61 46 00 00 00 a0  Device Fault; Error: ABRT
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  ef 03 46 00 00 00 a0 08   6d+18:56:45.628  SET FEATURES [Set transfer mode]
  ec 00 00 00 00 00 a0 08   6d+18:56:45.613  IDENTIFY DEVICE
  c8 00 40 00 e9 e6 e0 08   6d+18:56:44.945  READ DMA
  ec 00 00 00 00 00 a0 08   6d+18:56:44.919  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 08   6d+18:56:44.899  SET FEATURES [Set transfer mode]
Error 50755 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
  04 61 40 00 e9 e6 e0  Device Fault; Error: ABRT 64 sectors at LBA = 0x00e6e900 = 15132928
  ec 00 00 00 00 00 a0 08   6d+18:56:44.884  IDENTIFY DEVICE
  c8 00 40 00 e9 e6 e0 08   6d+18:56:44.216  READ DMA
Error 50754 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
  ec 00 00 00 00 00 a0 08   6d+18:56:44.189  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 08   6d+18:56:44.170  SET FEATURES [Set transfer mode]
Error 50753 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
  ec 00 00 00 00 00 a0 08   6d+18:56:44.154  IDENTIFY DEVICE
  c8 00 40 00 e9 e6 e0 08   6d+18:56:43.487  READ DMA
Error 50752 occurred at disk power-on lifetime: 10182 hours (424 days + 6 hours)
  ec 00 00 00 00 00 a0 08   6d+18:56:43.460  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 08   6d+18:56:43.440  SET FEATURES [Set transfer mode]
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
root@WDMyCloud root #
İçinde tek WD RED / RED Plus 2TB (WD20EFZX / WD20EFRX / WD20EFAX) war.
Üstelikte firmware diskin içine gömülü.
WD sanırım artık destek te wermiyor.
Ne dersiniz yeni bir hard disk alıp denesemmi?
Disk 10182 saat çalışmış ömrünü tamamlamış zaten.
Ağdan dosya/klasör yedekleme,medya sunucusu gibi arayüz özellikleri mevcuttu.4 tb modelini kullanmıştım
önce firmware imajı bulmak lazım. ve mümkünse aynı marka model disk ile denemek iyi olur. bu tip nasların genelde diske özel smart özelliklerini yönetmek gibi talepleri oluyor. farklı bir marka modelde o parametreleri çekemeyince hata verebilir.
ama nas işine girilecekse bu çok da yetenekli bir cihaz değil. synology ya da qnap'ın tek diskli ev tipi çok pahalı olmayan nasları var. içinde envai çeşit özellik mevcut, farklı uygulamalar yüklenebiliyor vs.
Elde kıyıda köşede yedekte duran bir tane 2.5” bile olsa bir tane diskle kurulum yapar denerdim.
Firmware diskin içine mi gömülü,yoksa kart üzerinde sarı boyalı bi entegre var ona mı gömülü ?
Buna çok benzeyen, neredeyse aynı ama rengi siyah olan vardı bende. Üzerinde uClinux çalışıyor ve root şifresi de internette yayınlandı. Bağımsız çalışan ve az enerji harcayan bir linux sistemi olarak iyi iş görür. Mesela DNS server çalıştırabilirsin. Veya VPN client koyarsın ve bunu gateway yaparsın, sonra da ağdaki her cihaz VPN üzerinden internete çıkabilir. Zamanında müzik servisleri entegrasyonu yaparken bu çok işime yaramıştı. Türkiye bir müzik servisini bloklamıştı, benim de işim var, bu şekilde servisi kullanmaya devam edip işi tamamlamıştım. Veya üzerinde web sunucusu çalıştırabilirsin. Mesela web tabanlı bug takip yazılımları var, veya komponent envanter takip programları.
Nasıl yapılacağından bi haber olunca uzaylı biri anlatmış gibi geldi bana yaw.
İçinde yürütülebilir servis programlar barındırma özelliği warmı bilmiyom.
Sadece CMD/PowerShell üzerinden SSH ile bağlanmayı öğrendim ben.
İçinde medya bölümü ve bi "Twonky" diye acaip servis daha war ne işe yaradığını bile bilmiyom.
GPT Dediki..
7) Medya Sunucusu (DLNA)​
Gönderdiğin resimde “Medya Aygıtı” olarak görünmesi normal.
Bu, MyCloud üzerinde çalışan Twonky DLNA medya sunucusudur.
  • Akıllı TV
  • Telefon
  • Tablet
üzerinden film/foto/müzik açabilirsin.
huseyin6334
