Gokrtl
Gökhan Kartal (TeknoDay)
27 Şubat 2019
Basit Elektronik Yük Devresi V1: https://mekatronik.org/forum/threads/basit-elektronik-yuek-devresi.5915/
Yukarıdaki linkte basit bir elektronik yük devresi yapmıştık.
Bu konu içerisinde bu yük devresini biraz daha geliştireceğiz.
Ben halihazırda kendi başıma proje yapacak yetkinlikte olmadığım için konu @taydin 'in yönlendirmesi ile ilerleyecek ama herkesin fikrini, önerilerini de yazmasını isterim. Konu tartışmaya açıktır. Yeter ki bluetoot filan eklemek gibi ileri seviye öneriler olmasın.
ELEKTRONİK YÜK V2
BOM LIST:
C1,C7,"10uF","~","Capacitor_THT:C_Radial_D5.0mm_H11.0mm_P2.00mm","2",""
C2,C5,C6,C8,C9,C10,C19,"100nF","~","Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder","7",""
C3,C4,"470uF","~","Capacitor_THT:C_Radial_D8.0mm_H11.5mm_P3.50mm","2",""
C11,C12,C13,C14,"330pF","~","Capacitor_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm","4",""
C15,C16,C17,C18,"100pF","~","Capacitor_SMD:C_1206_3216Metric_Pad1.33x1.80mm_HandSolder","4",""
D1,D2,"RB155","https://www.rectron.com/public/product_datasheets/rb151-rb157.pdf","Diode_THT:Diode_Bridge_Round_D9.0mm","2",""
J1,"220VAC","~","TerminalBlock_Phoenix:TerminalBlock_Phoenix_MKDS-1,5-2_1x02_P5.00mm_Horizontal","1",""
J2,"FAN-1","~","Connector_JST:JST_EH_B2B-EH-A_1x02_P2.50mm_Vertical","1",""
J3,"FAN-2","~","Connector_JST:JST_EH_B2B-EH-A_1x02_P2.50mm_Vertical","1",""
J4,"INPUT","~","TerminalBlock_Phoenix:TerminalBlock_Phoenix_PT-1,5-2-5.0-H_1x02_P5.00mm_Horizontal","1",""
J5,"FAN-3","~","Connector_JST:JST_EH_B2B-EH-A_1x02_P2.50mm_Vertical","1",""
Q1,Q2,Q3,Q4,"IRFP260N","http://www.irf.com/product-info/datasheets/data/irlz44n.pdf","Package_TO_SOT_THT:TO-247-3_Vertical","4",""
R1,"100K","~","Resistor_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal","1",""
R2,R3,R4,R5,"100R","~","Resistor_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P15.24mm_Horizontal","4",""
R6,R7,R8,R9,RV1,"10K","~","-- mixed values --","5",""
R10,R11,R12,R13,"0.22R 11W","~","Resistor_THT:R_Radial_Power_L12.0mm_W8.0mm_P5.00mm","4",""
R14,R15,R16,R17,"1K","~","Resistor_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizontal","4",""
T1,"RN148144
U1,U2,"LM358"
U3,U4,"L7812"
Hmm bu devrede eksi besleme görünmüyor ...
Ha pardon, sol kenara saklanmış :)
Beslemeleri doğrudan opamp hizasına alsak daha anlaşılır olur. Bir de FAN için bağımsız bir besleme kullanmakta fayda var. Acaba üç sargılı mini trafo var mıdır?
Devrede eksi besleneye gerek yok ki, opampı lm324 gibi negatife çok yakalaşan bir tanesi yapıp, ya da -sat da verdiği voltajı mosfet in thresholdundan düşük kalan bir tanesi yapıp devam edilebilir.
Şönt üzerinde çok küçük bir voltaj düşebilecek eğer akım ayarı düşük ise. Bu kadar düşük voltajda bile lineer çalışabilecek bir RR opamp bulmaya çalışacağına negatif besleme kullanmak daha mantıklı değil mi?
0.1 lik shunt ile 50mA de LM324 ile çalıştığımı hatırlıyor gibiyim, bu değilse 358 hatta 741 bile olabilir. Negatif besleme hep dert. Negatif beslemek yerine 12V tek kaynağı 6-6 bölmeyi bile değerlendiririm
Benim bildiğim girişler Vcc/Vee ye çok yakın yapılırsa opamp performansının bundan etkilendiği. Ama denemek lazım. Girişler şasenin birkaç mV üzerinde iken elektronik yükün üzerinde düşen voltajda büyük değişim yapılırsa, mesela 2V - 30V arasında değişirse halen sabit akım çekmesini sağlıyorsa tek besleme olabilir.
Ne yapıyoruz? 1.Mesajdaki şemayı tek besleme ile breadboarda kurup deniyor muyuz?
Değişik alternatifler her zaman denenebilir. Tek beslemeyi de deneriz. Ama önce çalışan birşey ortaya çıksın bence.
Öncelikle var olan devreyi çalışır hale getir. PCB perişan da olsa bir şekilde çalıştırılır o. Opamp ne kadar akım çekiyor. Fan ne kadar akım çekiyor, onları tespit edelim. Ona göre güç ortaya çıkar. Tek besleme işini deneyelim. Eğer tek besleme ile halloluyorsa o zaman iki sargılı fındık iş görür, bunlar da piyasada var.
Abi o devreye Bir tane IRFP260 taktım mı çalışır hale geliyor. O kolay da akımı nasıl ölçeceğiz bu kadar küçük devre de?
Ancak güç kaynağına seri multimetre bağlayıp toplam çektiği akımı bulmak daha kolay olur ki orada da simetrik besleme konusu var.
İkisinin çektiği akımı ayrı ayrı ölçüp toplayacağız doğru düşündüysem?
Bakamıyorum. simetrik besleme olduğu için GND hattında + - birleşik. Osiloskop probunu deydirince, osiloskopu korumaya alıyor.
Osiloskopu yaktım sandım, aklım çıktı.
Beslediğin kaynaklar izole değil mi?
Değil miş demek ki. :katil2:
Güç kaynağını 2-3 sene önce yaptım. İzole nedir onu bile bilmiyordum o zamanlar.
2x24v ortak uçlu trafom vardı. Orta ucu kesip tek kart üzerinde iki ayrı güç kaynağı devresi yaptım. LM317 ve 2SA1943 ile.
Devre şu olması lazım. Sonradan oynamadıysak.
Bu benim halilazırda kullandığım simetrik güç kaynağım.
Senin bu güç kaynağının prizdeki toprak ile bir şekilde bağlantısı var o zaman. Bulup ortadan kaldırmak lazım.
Evet toprağa bağlantısı var. Hatta 3 gün önce yoktu. @TA3UIS "niye bağlantısı yok, tehlikeli" filan diyince bende toprağa hat çektim. :D
bayarelektronik3
