Serial portta farklı karakterler çıkıyor
emcinar
16 Şubat 2023
Merhabalar,
Arduino nano ile dht11 sensörü kullanmak istiyorum. İlk deneyimim. Bir firmanın youtube kanalından izlediğim video üzerine parçaları sipariş ettim. Yine aynı kanaldaki yönergeleri uyguladım. Serial port ekranında sürekli soru işareti vb karakterler çıkıyor. Örnekler kısmındaki kod aşağıdaki gibidir:
//-*- mode: c++; c-basic-offset: 2; -*-
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
// REQUIRES the following Arduino libraries:
// - DHT Sensor Library: https://github.com/adafruit/DHT-sensor-library
// - Adafruit Unified Sensor Lib: https://github.com/adafruit/Adafruit_Sensor
#include "DHT.h"
#define DHTPIN 2 // Digital pin connected to the DHT sensor
// Feather HUZZAH ESP8266 note: use pins 3, 4, 5, 12, 13 or 14 --
// Pin 15 can work but DHT must be disconnected during program upload.
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 3 (on the right) of the sensor to GROUND (if your sensor has 3 pins)
// Connect pin 4 (on the right) of the sensor to GROUND and leave the pin 3 EMPTY (if your sensor has 4 pins)
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors. This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
void setup() {
  Serial.begin(9600);
  Serial.println(F("DHTxx test!"));
  dht.begin();
void loop() {
// Wait a few seconds between measurements.
  delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
// Read temperature as Celsius (the default)
  float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
// Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print(F("Humidity: "));
  Serial.print(h);
  Serial.print(F("% Temperature: "));
  Serial.print(t);
  Serial.print(F("°C "));
  Serial.print(f);
  Serial.print(F("°F Heat index: "));
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(F("°F"));
nerede hata yapıyorum yardımcı olabilir misiniz?
Serial monitörde baud rate'in solunda yeni satır yazıyor. Oradaki seçenekleri hatırlamıyorum. Onları değiştirip dene.
Birde yeni bir sketch açıp kendin serial monitöre bir şey yazdırmayı dene. Bakalım kodda mı hata var yoksa programda mı.
İlginiz için teşekkür ederim. O seçenekleri denedim değişiklik olmadı. 16x2 ekran da var kodlar onu çalıştırıyor.
Ekranı geç. Serial monitöre yeni bir sketch açıp manuel olarak bir şey yazdır. Mesela "Merhaba Dünya"
Bunu düzgün yazarsa senin dht kodlarında yada kütüphanende bir sıkıntı var demektir. Yok eğer düzgün yazmazsa o zaman arduino idende yada bilgisayar dilinde bir problem olabilir.
Program kodu ekleyeceğin zaman editördeki "Kod" butonunu kullanırsan program daha anlaşılır olur.
String'leri yazdırırken etrafına F() makrosunu koymuşsun. Bu makro, string'lerin flash bellekte olduğunu ifade ediyor. Flash bellekte o string'ler yoksa saçma sapan şeyler yazar. F() makrolarını kaldırıp deneyebilirsin.
Hmm şimdi baktım da, F() makrosu zaten doğrudan string'i flash belleğe koyuyormuş. O zaman sorun başka bir yerde.
Lokumlu Lahmacun
