1.5V~15V Charge Pump TC7662A, TC7662B
Dede
24 Mayıs 2024
TC7662 Charge Pump DC-to-DC Voltage Converter
Features
• Wide Operating Voltage Range: 1.5V to 15V
• Boost Pin for Higher Switching Frequency (Pin 1)
• High-Power Efficiency is 96%
• Easy to Use – Requires Only 2 External Non-Critical Passive Components
• Improved Direct Replacement for Industry Standard ICL7660 and Other Second Source Devices
Applications
• Simple Conversion of +5V to ±5V Supplies
• Voltage Multiplication V OUT = ±nVIN
• Negative Supplies for Data Acquisition Systems and Instrumentation
• RS232 Power Supplies
• Supply Splitter, V OUT = ±VS/2
iclal
