Dede
- Katılım
- 24 Mayıs 2024
- Mesajlar
- 1,545
Birçok arkadaşımız STM nin ARM çiplerini daha çok seviyor olsada Microchip te kendi çapında ARM İşlemci imal ediyor.
Ancak çokta harcıalem olmayan daha çok endüstriyele hitabedebilecek ürünler.
Olur ya...
Belki savunma yada uzay teknolojisine İş yapma niyetinde olanlar için uygun bir işlemci.
SAMD21RT Datasheet
Radiation Tolerant, Low-Power, 32-bit Cortex-M0+ MCU with Advanced Analog and PWM
Features:
• Processor
– Arm® Cortex®-M0+ CPU running at up to 48 MHz
• Single-cycle hardware multiplier
• Micro Trace Buffer (MTB)
• Memories
– 4 KB Read-While-Write (RWWEE) Flash section
– 128 KB in-system self-programmable Flash
– 16 KB SRAM Memory
• System
– Power-on Reset (POR) and Brown-out Detection (BOD)
– Internal and external clock options with 48 MHz Digital Frequency-Locked Loop (DFLL48M)
and 48 MHz to 96 MHz Fractional Digital Phase-Locked Loop (FDPLL96M)
– External Interrupt Controller (EIC)
– 16 external interrupts
– One Non-maskable Interrupt (NMI)
– Two-pin Serial Wire Debug (SWD) programming, test and debugging interface
• Low Power
– Idle Sleep mode
• Peripherals
– 12-channel Direct Memory Access Controller (DMAC)
– 12-channel Event System
– Five 16-bit Timer/Counters (TC), configurable as either:
• One 16-bit TC with two compare/capture channels
• One 8-bit TC with two compare/capture channels
• One 32-bit TC with two compare/capture channels, by using two TCs
– Four 24-bit Timer/Counters for Control (TCC), with extended functions:
• Four compare channels with optional complementary output
• Generation of synchronized pulse width modulation (PWM) pattern across port pins
• Deterministic fault protection, fast decay and configurable dead-time between
• Dithering that increase resolution with up to 5 bit and reduce quantization error
– PWM Channels using TC and TCC peripherals:
• Eight PWM channels on each 24-bit TCC
• Two PWM channels on each 16-bit TCC
– 32-bit Real Time Counter (RTC) with clock/calendar function
– Watchdog Timer (WDT)
– CRC-32 generator
– One full-speed (12 Mbps) Universal Serial Bus (USB) 2.0 interface
• Embedded host and device function
• Eight endpoints
– Six Serial Communication Interfaces (SERCOM), each configurable to operate as either:
• USART with full-duplex and single-wire half-duplex configuration
• I2C up to 3.4 MHz
• SPI
• LIN client
– One two-channel Inter-IC Sound (I2S) interface
– One 12-bit, 350ksps Analog-to-Digital Converter (ADC) with up to 20 channels
• Differential and single-ended input
• 1/2x to 16x programmable gain stage
• Automatic offset and gain error compensation
• Oversampling and decimation in hardware to support 13-, 14-, 15- or 16-bit resolution
– 10-bit, 350 ksps Digital-to-Analog Converter (DAC)
– Two Analog Comparators (AC) with Window Compare function
– Peripheral Touch Controller (PTC)
• Up to 256-Channel capacitive touch and proximity sensing
• I/O
– 52 programmable I/O pins
• Operating Conditions
– Supply voltage: 3.0V to 3.6V
– Operating temperature: -40 °C to +125 °C
• Packages
– CQFP, 64-lead, 1.08g (2.56g with tie-bar)
– TQFP, 64-lead, 0.27g
• Radiation Performance
– Total dose: 50 krad (Si)
Single Event Latch-up immunity > 78 MeV.cm2/mg (+125 °C)
Detailed results about TID, SEL and SEU available upon request.
• ESD
– HBM: 4kV
– CDM: 500V
Olur ya...
SAMD21RT Datasheet
Features:
• Processor
• Memories
– 16 KB SRAM Memory
• System
• Low Power
– Idle Sleep mode
• Peripherals
– CRC-32 generator
• Eight endpoints
• I2C up to 3.4 MHz
• SPI
• LIN client
• I/O
• Packages
• ESD
– HBM: 4kV
– CDM: 500V
