Radyasyona Dirençli ARM 32-bit Cortex-M0+ MCU
Dede
24 Mayıs 2024
Birçok arkadaşımız STM nin ARM çiplerini daha çok seviyor olsada Microchip te kendi çapında ARM İşlemci imal ediyor.
Ancak çokta harcıalem olmayan daha çok endüstriyele hitabedebilecek ürünler.
Olur ya...
Belki savunma yada uzay teknolojisine İş yapma niyetinde olanlar için uygun bir işlemci.
SAMD21RT Datasheet
Radiation Tolerant, Low-Power, 32-bit Cortex-M0+ MCU with Advanced Analog and PWM
Features:
• Processor
– Arm® Cortex®-M0+ CPU running at up to 48 MHz
• Single-cycle hardware multiplier
• Micro Trace Buffer (MTB)
• Memories
– 4 KB Read-While-Write (RWWEE) Flash section
– 128 KB in-system self-programmable Flash
– 16 KB SRAM Memory
• System
– Power-on Reset (POR) and Brown-out Detection (BOD)
– Internal and external clock options with 48 MHz Digital Frequency-Locked Loop (DFLL48M)
and 48 MHz to 96 MHz Fractional Digital Phase-Locked Loop (FDPLL96M)
– External Interrupt Controller (EIC)
– 16 external interrupts
– One Non-maskable Interrupt (NMI)
– Two-pin Serial Wire Debug (SWD) programming, test and debugging interface
• Low Power
– Idle Sleep mode
• Peripherals
– 12-channel Direct Memory Access Controller (DMAC)
– 12-channel Event System
– Five 16-bit Timer/Counters (TC), configurable as either:
• One 16-bit TC with two compare/capture channels
• One 8-bit TC with two compare/capture channels
• One 32-bit TC with two compare/capture channels, by using two TCs
– Four 24-bit Timer/Counters for Control (TCC), with extended functions:
• Four compare channels with optional complementary output
• Generation of synchronized pulse width modulation (PWM) pattern across port pins
• Deterministic fault protection, fast decay and configurable dead-time between
• Dithering that increase resolution with up to 5 bit and reduce quantization error
– PWM Channels using TC and TCC peripherals:
• Eight PWM channels on each 24-bit TCC
• Two PWM channels on each 16-bit TCC
– 32-bit Real Time Counter (RTC) with clock/calendar function
– Watchdog Timer (WDT)
– CRC-32 generator
– One full-speed (12 Mbps) Universal Serial Bus (USB) 2.0 interface
• Embedded host and device function
• Eight endpoints
– Six Serial Communication Interfaces (SERCOM), each configurable to operate as either:
• USART with full-duplex and single-wire half-duplex configuration
• I2C up to 3.4 MHz
• SPI
• LIN client
– One two-channel Inter-IC Sound (I2S) interface
– One 12-bit, 350ksps Analog-to-Digital Converter (ADC) with up to 20 channels
• Differential and single-ended input
• 1/2x to 16x programmable gain stage
• Automatic offset and gain error compensation
• Oversampling and decimation in hardware to support 13-, 14-, 15- or 16-bit resolution
– 10-bit, 350 ksps Digital-to-Analog Converter (DAC)
– Two Analog Comparators (AC) with Window Compare function
– Peripheral Touch Controller (PTC)
• Up to 256-Channel capacitive touch and proximity sensing
• I/O
– 52 programmable I/O pins
• Operating Conditions
– Supply voltage: 3.0V to 3.6V
– Operating temperature: -40 °C to +125 °C
• Packages
– CQFP, 64-lead, 1.08g (2.56g with tie-bar)
– TQFP, 64-lead, 0.27g
• Radiation Performance
– Total dose: 50 krad (Si)
Single Event Latch-up immunity > 78 MeV.cm2/mg (+125 °C)
Detailed results about TID, SEL and SEU available upon request.
• ESD
– HBM: 4kV
– CDM: 500V
Cehaletime dayanarak soruyorum Timur hocam. Bu işlemciler ile şeytana uyup nasıl bir illegal işe dalınabilir?
İllegal işler için bunlar uygun olmaz. Performansları çok düşük mevcut teknoloji seviyesine göre. Fiyatları da korkunç yüksek. Bunların iki ana kullanım alanı var:
1) Uzay teknolojileri
2) Nükleer tesisler
Amerikan İmparatorluğu da kesinlikle hiç kimseye bu konularda yardımcı olmak istemez :)
Radyasyona direncli devre yapmak icin illa cipin radyasyona direncli olmasi sart mi?
Kutu ile de onlem alinabiliyordur. Sonucta 60'larda uzaya onca cihaz gitti geldi.
Belgeselde izlemistim uzay cihazinin icindeki insanlari 3mm aluminyum levha uzaydaki radyasyondan koruyor denmisti.
Benim anladığım, ortaya çıkan sorun "bit flip". Yani bir register veya bellekteki bitin, radyasyon partikülleri nedeniyle değer değiştirmesi.
Eğer CPU yu radyasyonu baskılayan bir kutuya koyarsan, sadece bit flip ihtimalini azaltıyorsun. Ama radyasyona dayanıklı CPU kullanırsan, bit flip olma durumu ortadan kalkıyor. Veya sıfıra yakın bir ihtimale düşüyor.
eski sistemlerde bir işlemi birden fazla cpu'da yaptırıp (5 diye hatırlıyorum apollolarda) yarıdan fazla çoğunluğu doğru sonuç kabul ediyorlarmış
Mario oyunlarından bir tanesinde speedrun yapılırken bir kullanıcı, güneşte olan patlamadan gelen bir dalga sayesinde, karakterin tek seferde zıplayamaması gereken yere zıplamıştı. Araştırıp bakıp sonucunda registera kayıtlı olan zıplama bitlerinden bir tanesini flip ettiğini bulmuşlar. Zaman zaman güneşten gelen radyasyon bile bitleri flip edebiliyor.
Radyasyona karşı koyabilen yeğane materyal şimdilik kurşun.
Diğer materyaller elek gibi.
Gelenin bir kısmını tutabilirken diğerlerini (Çoğunluğunu) geç kardeşim diyerek (rüşvet vs karşılığında) salıveriyorlar.
Sanırım bu çiplerde ise bir kurşun kutucuğun içine çip yerleştiriliyor olsa gerek.
Yoksa radyasyona dirençli diye satmaları anlamsız.
Alfa Beta Gamma çok ta ferman dinlemiyor kısacası...
neutronlara karşı pek etkili değil.
Bir yerde duymuştum, daha kalın yarım iletken imalat prosesleri kullanıyorlar, ama mühtemelen tek farkı bu değil.
Kurşun kılıfta yapmaları sorun yaratabilir, yüksek ivmelerde pcb lehim kontakları fazladan baskıya maruz kalır.
Biraz bakindim da radyasyona dayali lojik devre tasarimi yapi anlaminda bir hayli farkliymis.
Mesela FF icin 2 geribeslemeli yapi yeterli iken radyasyona dayanikli yapida 4 geri beslemeli yapi kullaniliyormus.
Yazilim icin de mantik farkli mantik yurutuluyormus.
Çok ince kaplamalar halinde olursa fazlaca etkizi olmaz zannımca. Zaten seramik kılıf çoğu. Seramik te çok hafif malzeme değil.
apnr
