#include <LiquidCrystal.h> // include the library for the LCD
#include <DHT.h> // include the library for the DHT11 temperature sensor
#include <Stepper.h> // include the library for the stepper motor
// set up the LCD's number of columns and rows:
const int numRows = 2;
const int numCols = 16;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// set up the DHT11 temperature sensor
#define DHTTYPE DHT11 // specify the type of DHT sensor
#define DHTPIN A0 // specify the pin the DHT sensor is connected to
DHT dht(DHTPIN, DHTTYPE); // create a DHT instance
// set up the stepper motor
const int stepsPerRevolution = 200; // specify the number of steps per revolution
Stepper stepper(stepsPerRevolution, 0, 1, 2, 3); // create a Stepper instance and specify the pins the motor is connected to
void setup() {
  lcd.begin(16, 2);
 lcd.setCursor(0,0);
 lcd.print(" Sicaklik Olcer");
 delay(1000);
 lcd.clear();
 Serial.begin(9600);
 delay(100);
  // initialize the DHT11 sensor
  dht.begin();
  // set the speed of the stepper motor in steps per second
  stepper.setSpeed(600);
void loop() {
  // read the input from the LCD button shield
  int buttonInput = readButtonInput();
  // read the temperature and humidity from the DHT11 sensor
  float temp = dht.readTemperature(); // read the temperature in Celsius
  float humi = dht.readHumidity(); // read the humidity in percent
 lcd.setCursor(9,2);
  lcd.setCursor(0,0);
  lcd.print("Sicaklik:");
  lcd.setCursor(9,0);
  lcd.print(temp);
  lcd.setCursor(12,0);
  lcd.print("'C");
  lcd.setCursor(0,2);
  lcd.print("Nem:");
  lcd.setCursor(5,2);
  lcd.print(humi);
  lcd.setCursor(8,2);
  lcd.print("%");
  delay (100);
  // compare the temperature from the sensor with the input from the button shield
  if (temp > buttonInput) {
    // run the stepper motor if the temperature is higher
    stepper.step(stepsPerRevolution); // rotate the motor one revolution
  } else {
    // do something else if the temperature is not higher
// function to read the input from the LCD button shield
int readButtonInput() {
  // read the input from the button shield
  int buttonInput = analogRead(A1);
  // map the input to a value between 0 and 100
  buttonInput = map(buttonInput, 0, 1023, 0, 100);
  // return the mapped value
  return buttonInput;
